Preamp suggestions?
Everything Phatty.
solman52
Preamp suggestions?
Post by solman52 » Wed Apr 29, 2009 5:32 pm
running my LP into a Motu828mkII, and using logic pro studio, problem is my LP bass sounds real quiet when i play or record. i checked the soundcard settings for the inputs and they are maxed. Do i need a preamp?
CTRLSHFT
Re: Preamp suggestions?
Post by CTRLSHFT » Wed Apr 29, 2009 5:57 pm
solman52 wrote:running my LP into a Motu828mkII, and using logic pro studio, problem is my LP bass sounds real quiet when i play or record. i checked the soundcard settings for the inputs and they are maxed. Do i need a preamp?
I've noticed the output on the LP is a little quiet myself. I think though that the reason for this is that it's capable of being REALLY LOUD depending on how your patches are set. The overdrive will blow it up, with res down and the cutoff towards 7oclock or so you can generate some amazingly loud low end.
A preamp might be helpful, but be mindful that the LP will drive into it like a cement truck. :)
www.ctrlshft.com
jplanet
Post by jplanet » Tue May 19, 2009 2:57 am
At the very minimum, you'll need an active direct box to get a good level. The Whirlwind IMP2 is an industry standard and under $50...
For a few more dollars you could get a preamp/DI combo that will also allow you to record with mics...the M-Audio DMP3 or Studio Projects VTB-1 can produce professional results very inexpensively...
[url=http://www.shadowcircusmusic.com/audio/]Prog Lives!![/url]
DeFrag
Post by DeFrag » Tue May 19, 2009 10:20 am
Radial Engineering makes the best DIs available.
http://www.radialeng.com
Little Phatty TE #1023 • Schrittmacher • Walking Stick ribbon • Korg microXL/Electribe MX/KaossPro • Sonnus G2M
MF-101 Filter • MF-102 Ring • MF-103 Phaser • MF-104Z Delay • MF-105 MuRF • MF-107 FreqBox • MF-108M Cluster • Etherwave
_/_/_/_/_/_/_/_/
Portamental
Post by Portamental » Wed May 20, 2009 6:13 am
You might want to look at this : http://www.dbxpro.com/DirectBoxes/directboxes.php
I don't have one (chances are I will by the end of the month), but I have a 231 dbx equalizer. Very fine unit for the price.
Killer marketing video on the site, fun to watch!
D-rex
Post by D-rex » Sat Jun 06, 2009 8:57 pm
I use presonus tubepre with the LP and it makes a HUGE difference. Sounds alot warmer and louder when recording or just playing. Cost $100 new.
DSI Tetra, Vestax Controller One, Rane TTM-56, MF-102, MF-105, Korg Kontrol 49
anaivemistake
Post by anaivemistake » Tue Jun 09, 2009 12:02 pm
i have been building a lunchbox up for a couple years and I use the A-designs Silver for all my low register keyboard sounds. Its not cheap, but it sounds great with keyboards, especially bassy sounds. Its my lowend sound. It sounds good on Kick drums too.
moledog
Post by moledog » Tue Jun 09, 2009 12:14 pm
I've got a Studio Projects VTB-1 between my LP and 828mkii.
I swapped the standard tube with a JJ one and it sounds great.
Here's a site showing the mod...
http://bounav.free.fr/wp/?p=264
I got a refurbished VTB for £75 and the tube was £15.
