1V/oct is positive only. 5 octave range. If you want wide range, you program starting in range C3 (it goes from C1 to C6 and everything in between) and set your steps from there, giving you a couple of octaves in either direction. I believe C1 is -zero- volts.
If you're running steps programed down in the C1 range and hit a key on your controller (LP, Voyager or external midi keyboard) that takes you below -zero-, the sound gets bumped up to the C5-6 range....apparantly the voltage, when triggered into the below -zero- range, gets bumped up to the highest octave.
Still need a sequencer
Good info, thanks. All things considered I've never really had an issue w/ this before w/ my mobius which has the same limitation, you are able to get rediculously low if you want.acorkos wrote:1V/oct is positive only. 5 octave range. If you want wide range, you program starting in range C3 (it goes from C1 to C6 and everything in between) and set your steps from there, giving you a couple of octaves in either direction. I believe C1 is -zero- volts.
www.ctrlshft.com
A bit confused... how can you play lower ranges when some units don't support -5 to 0v?
Little Phatty TE #1023 • Schrittmacher • Walking Stick ribbon • Korg microXL/Electribe MX/KaossPro • Sonnus G2M
MF-101 Filter • MF-102 Ring • MF-103 Phaser • MF-104Z Delay • MF-105 MuRF • MF-107 FreqBox • MF-108M Cluster • Etherwave
_/_/_/_/_/_/_/_/
_/_/_/_/_/_/_/_/
