I've been using my Little Phatty Tribute for a few years now with no problems. But lately I've noticed a strange issue that seems to happen sporadically and then goes away.
The problem is that the buttons for the Filter section (cutoff, res., overload, kb and eg amount) and the Output On/Off button will not function properly. They will change as you flip through different presets, but you cannot change them within presets by pressing, or turn the output on or off. All of the other buttons in other sections and all knobs work correctly. Then, usually, it will just work correctly seemingly out of nowhere.
Any ideas or similar stories? Please??
Problems with my LPT's Filter Bank / Output buttons...
I have had the same phenomena with the EG buttons since I upgraded to OS2.01TE. It happens once in a while and is solved by restarting the LP. I don't know why.
Little Phatty TE #1045 | Etherwave Theremin
Stockholm, Sweden - - - Listen at: assar.se
