Updating Little Phatty OS
Hi there, I was just wandering what's involved in updating the Little Phattys OS?? I'm stumped!
Which Little Phatty ?
Model D, Little Phatty Tribute w/cv, The Rogue, MF-102, CP-251, Animoog and Filtatron
links
http://www.amazon.com/M-Audio-Midisport ... B00007JRBM
http://www.midiox.com/
http://www.moogmusic.com/forum/viewtopi ... 00&start=0
This might help if you use windows.
Correct. Stage II side panel is only good if you need MIDI via USB. I have a Mac, so I did the OS update using an M-Audio UNO and sysex Librarian.Chris-Nic wrote:Stage I Edition. Am i right in saying upgrading to Stage II doesn't need a changed side panel, just and OS update?
Phatty poly or mono?
Hi! Can anyone please tell me if the Little Phatty is only a mono-melodic synth or you can play chords with it?
thank you.
gabriel,.
thank you.
gabriel,.
If you look on the product page of the Little Phatty Stage Edition / Specs. ( http://www.moogmusic.com/littlephatty/? ... uct_id=254 )...you will see the following :
The Little Phatty is a monophonic analog synthesizer, with 100 user editable presets.
