i had a scary evening a few nights ago - when i turned on my LP with recently installed OS2 the sound appeared to be extremely unsettled. even stranger though was when i moved the osc2 freq near to an LED trigger frequency, the nearest LED would also flicker to represent the frequency inconsistencies.
even on the basic calibration patch the filter frequency and most other variable settings where being randomly modulated.
environmentally, the room it exists in has usually one person and is most certainly under average room temperature and i had been away for a few days more than i usually am so the lack of body warmth may have affected it a little more? i couldn't figure it out; it still hadn't settled even after leaving it on for 6 hours!
today though, having been around for a few days it's back its good old raucious self, thankfully!
are there any obvious reasons for the temporary defects i experienced?
cheers
strange behaviour
Yes, use a grounded power outlet.are there any obvious reasons for the temporary defects i experienced?
[size=75]"I like to play with electronic noise makers. I hope someone wants to listen, and if not, I'll still be up at 3 am making sequences in the dark, drinking coffee, and burning expensive incense." [i]Rod Modell[/i][/size]
Usually things like this are power-related so it's the first thing to check. Try to use another power socket instead of the one you're using now, just to be sure.
