Moog Music Forum
Share Ideas and Pass the word
LFO sync setting per patch
Little Phatty • Slim Phatty
Postby Roger Paolo » Thu Feb 09, 2017 3:28 pm
Hi there,
I am stoked with the opportunity to both globally and 'locally', per patch, being able to adjust arpeggiator settings.
As far as I know this can not be done for the LFO sync: I can sync the LFO to external midi globally but then this applies to every selected patch. Or am I overlooking a setting where I can do this?
With almost every sound I do like the LFO to sync to the Ableton Live rig we use on stage, but on one particular patch it needs to be out of sync.
cheers, Rodg.
Roger Paolo
Re: LFO sync setting per patch
Postby stiiiiiiive » Thu Feb 09, 2017 7:00 pm
On the Little Phatty, it is impossible as far as I know. I use it in a couple of projects, one of which need the sync all the way and not the other: I have to remember to switch into the right mode.
stiiiiiiive
Postby Roger Paolo » Fri Feb 10, 2017 4:05 am
ok, so I won't look further. next question pops up in my head: would it be possible to control that setting (LFO sync source) with a MIDI control message?
Roger Paolo
Postby stiiiiiiive » Fri Feb 10, 2017 9:15 am
Just check the online manual MIDI charts :)
EDIT - from the manual :
Name: LFO SYNC SOURCE
Description: Selects the LFO synchronization source
CC#: 102
Values: 0 (INT), 64 (MIDI CLK)
stiiiiiiive
Postby Roger Paolo » Sat Feb 11, 2017 6:52 am
bam, that's what I need. Now I can program the sync source from the ableton project! thanks a million.
Roger Paolo
Postby stiiiiiiive » Sat Feb 11, 2017 1:26 pm
Hallelujah! 8)
stiiiiiiive
Return to The Phatty Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
