Moog Music Forum
Share Ideas and Pass the word
Slim Phatty Midi Issues Logic Pro X
Little Phatty • Slim Phatty
Postby Microman » Mon Jan 09, 2017 12:46 am
Hey Guys! my name is Diego, I'm Having serious Issues with my SP & Logic, Apparently I can't get sound out of my SP when I use External Instrument(when I Create External Midi Channel), If, I DON'T select the external Instrument It DOES Sound but i can't REC that kind of channel not even bus it or something like that... PLEASE HELP ME :( :oops: , I've had no response from the Moog team so far.
Diego :)
Microman
Re: Slim Phatty Midi Issues Logic Pro X
Postby autoy » Fri Jan 13, 2017 10:49 am
Your issue is software related, Logic side. You have to set up your external instrument plugin so you tell it which MIDI output is it connected to (I assume you have it correct because you're hearing sounds) and the oudio input of your soundcard where you have connected it. You will be then ready for MIDI recording of your track and monitoring it through the input. If you want to render the audio just open a new audio track and assign it to the soundcard input where the synth is, then record only that track while the MIDI parts play the external instrument.
autoy
Return to The Phatty Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 2 guests
