Sub Phatty Activate panel problem
Everything Phatty.
misfitit
Re: Sub Phatty Activate panel problem
Post by misfitit » Thu Sep 08, 2016 6:06 pm
so far everything seems to function
here's from over on the Sub Forum....
http://forum.moogmusic.com/viewtopic.php?f=21&t=26093
Antoine
Post by Antoine » Fri Sep 09, 2016 2:58 am
Thanks a lot Misfitit,
after resetting the parameter as show on that topic, my sub phatty is back to work in the Activate panel.
cool. :D , let's jam !!
misfitit
Post by misfitit » Fri Sep 09, 2016 12:12 pm
Nice one
makrostorung
Post by makrostorung » Sun Aug 06, 2017 10:17 am
Had the same problem:
1 activate panel
2 press and hold preset (now you should see the preset edi page for the panel mode)
3 go down to "preset vol" in my case it was at 1%
4 crank that up (I put it at 100%)
done
And keep smiling °L°
C59
Post by C59 » Sat Nov 04, 2017 2:55 pm
Hi, I got the same problem after I updated my moog sub 37.
Solved the problem by accessing global menu 3.2 "init settings" and then pressed "save" for 5 second.
After that everything fine.
cheers
C59
