Moog Music Forum
Share Ideas and Pass the word
LP Tribute Env Release Problem
Little Phatty • Slim Phatty
Postby PHC » Wed Aug 10, 2016 3:18 pm
Lately my LP started acting wierd. Sometimes the Release on both envelopes jumps to max (usually when changing presets) and I can't change it unless I turn the pot to 0 and then it unlocks.
I would suspect a bad pot, but this only happens when adjusting the Release, no problem with A, D, S.
Any ideas?
PHC
Re: LP Tribute Env Release Problem
Postby bichuelo » Wed Aug 10, 2016 4:47 pm
The Release function can be switched on an off from an option you can find on the display menu. This might be set differently in each preset
http://audiotecna.info
T-III, Voyager, VX-351, Slim Phatty, Model D, Sub Phatty, Sub 37, Minitaur, all moogerfoogers and minifoogers, EW+, Theremini, Model 15 App, Filtatron Animoog, iOS 10 Mother-32, Werkstatt, Windows 7, Capitan, Snow Leopard, WinXP
bichuelo
Postby PHC » Wed Aug 10, 2016 4:54 pm
I know, but I don't see how this is related to my problem?
PHC
Postby Moogtard » Wed Sep 28, 2016 3:06 pm
Could be an internal midi signal assigned to the env cc's continually being sent some reason. Have you tried a factory reset? Is your operating system up to date? have you tried a different pot mode? pass though, snap, and what ever the third one is. I believe thats the one I use the most actually.
Moogtard
Return to The Phatty Forum
Who is online
Users browsing this forum: Bing [Bot], CommonCrawl [Bot], Google [Bot] and 2 guests
