Hi guys!
Hope you're having a fantastic day Just a quick question: Does someone knows how to detune single oscillators in the Sub Phatty? When I use the "Fine Tune" Knob, I tune automatically both osczillators. I want to use it to detune the Oscillators a little bit against each other, to make the sound bigger.
Thanks for your tipps!
Best,
Alex
Sub Phatty detune issue
Re: Sub Phatty detune issue
You can use the frequency knob in the oscillator 2 section to detune oscillator relative to oscillator 1.
Page 14 in the manual says:
FREQUENCY: This knob is used to fine-tune oscillator 2’s pitch within its selected range. The knob’s range is seven semitones higher or lower than its center position. At its center position, oscillator 2 is tuned to oscillator 1. Turning it just slightly out of tune with oscillator 1 can yield interesting detuned or phasing effects.
