New owner of a Sub 37 since several months. Been having a great time making new sounds, but I've recently noticed that the 2 oscillators are often slightly out of tune (by about 30 cents). I've done a note callibration, but it didn't seem to work. However, if I turn the fine tune knob to -7 and then back to 0 the oscillators come back into tune, so I'm wondering whether it's pot problem.
As an aside, I've also noticed that the two waveform knobs aren't quite identical either - the audible switch in tone from the triangle to saw doesn't quite happen in the same place on the two knobs. Again, is this normal (of course, I'm aware that being analog you can't quite expect everything to line up properly!), and if not is there a pot calibration that I can do?
Other than these small niggles, it's a great synth!
Thanks for any help.
