Sub37: Mod question for Kick drum creation
Everything Sub.
klfnk
Post by klfnk » Tue Jan 19, 2016 8:23 am
I've been creating drum sounds with my sub37 for some time now and bumped into this demo of a modular kick drum 'patch'.
https://youtu.be/gqh8mB4pDoU
The artist creates a kickdrum with an OSC and uses 2 EG's to create the vca and pitch envelope (sync triggered).
So I thought, could I create that same sound with the Sub37 ? I can sync the OSC and the EG's and trigger them with the ARP.
It's not as flexible as the modular setup, but it should be possible :)
Well... the problem is that I can't figure out how to pitch control OSC 1. I can pitch control OSC 2 (somewhat), by modulating
the frequency env. but it doesn' sound deep enough.. I want to use 2 OSC's to variate the waveshape..
Am I doing something wrong or is it simply not possible?
Cheers
Moog Sub 37
Ableton Live 8.latest
Pro Tools 12 HD12.latest
RME Fireface UC
15" MacBook Pro Retina 2015 Yosemite
paul_sub37
Re: Sub37: Mod question for Kick drum creation
Post by paul_sub37 » Tue Jan 19, 2016 8:56 am
there's a pitch knob on each mod bus, where you can select osc 1/2 or both as a mod destination (positive and negative).
Can't you just use that to dial in the amount and set the source on the mod bus to be one of the envelopes or the downward ramp (with kb reset) to get a kick drum pitch drop?
My Sub 37 Patches - Sub 37 + Mother 32 + UR-44 + OS X 10.11/Ableton Live/Logic Pro X + Push 2
paul_sub37
Post by paul_sub37 » Tue Jan 19, 2016 9:56 am
attached are sysex and wav files for a kick drum using the FEG and pitch knobs in the mod 2.
you can tune the sound using the main filter cutoff knob, the EG AMT knob and also the the PITCH AMT knob in MOD 2
kick.wav.zip
(263.93 KiB) Downloaded 103 times
Kick.syx.zip
(330 Bytes) Downloaded 104 times
klfnk
Post by klfnk » Tue Jan 19, 2016 10:14 am
[slaps his head]
why didn't i think of this!! :)
thanks paul i'll check out your patch, but first i'm gonna try it myself !!
Moog Sub 37
RME Fireface UC
paul_sub37
Post by paul_sub37 » Tue Jan 19, 2016 10:18 am
always the best way- have fun and good luck!
