to be honest it doesn't cause me enough grief to warrant the time needed to go through those steps - but at least it's a way to achieve it.Amos wrote:There is one way that definitely makes this work in Ableton, but it's a bit tedious... on the other hand, it might be the correct/only way, if there's not a way to make it automatic. (I may need to check with the Abes on this)
Sub 37 pre-release Editor 0.9.25 + firmware version 1.1.13
Re: Sub 37 pre-release Editor 0.9.25 + firmware version 1.1.
My Sub 37 Patches - Sub 37 + Mother 32 + UR-44 + OS X 10.11/Ableton Live/Logic Pro X + Push 2
- moonbooter
Just tried to install the 3.3 Midi driver in Windows 10 x64. But Windows always prefers the standart microsoft driver.
When I try to select it manually it don´t work (marked with a yellow sign n the device manager).
Any idea, how to install the Moog Midi driver (in order to intall latest firmware 1.2, in order to use the VST)?
Thanks in advance
Thanks in advance
HI moonbooter,moonbooter wrote:Just tried to install the 3.3 Midi driver in Windows 10 x64. But Windows always prefers the standart microsoft driver.
if you double-click the driver in device manager, is there any error text associated with the yellow sign?
If you haven't installed the beta firmware / are still using firmware v1.1.0 or so, then this is why it's not using the new driver.
New driver is looking for new firmware.
- moonbooter
Just tried it and it´s working fine. Thanks!
- dettenbach
Hiho Dears,
it seems i was a bit misinformed when buying the sub 37, assuming there is still an editor available (even if i like to teak with the knobs in many of my workflows, i hardly use plug out editors for my synth zoo - even some in beta state ß)
is it still possible to get a copy of the pre-release of the Editor (Mac)? If beta testing is wanted - i'm open to help a bit too.
If not, are there any updates regarding a public release (even as a beta or alpha).
many, many (many) thanks in advance,
Niels.
Niels.
((d^b))
dettenbach music fab
http://dettenbach.de
hard: MacBookPro 12.1 (late 2015)
soft: / OS 10.11.3 / Pro Tools 12.5 / Studio One 3.2
Have we any idea when the Editor et al will be formally released yet?
Grandmother, DFAM x 2, Mother 32 x 2, Sub 37, Minitaur, Theremini, MF-104M, MF-108M, MF-101, MF-102, MF-103, MF-105M, MF-107, CP-251 x 2.
I have a feeling around April, 2019.Spazige wrote:Have we any idea when the Editor et al will be formally released yet?
