Weird key response during legato key stroke
Everything Phatty.
jrivera
Post by jrivera » Fri Sep 25, 2015 2:19 am
Hi there,
I recently purchased the Moog Sub Phatty and absolutely love it.
However, I've been recording with it this week and working with a melody that has a sort of soft legato sound to it. Unfortunately I am getting a weird response randomly when I'm going back and forth between keys. Occasionally the key will not respond and the sound glitches out and then comes back. It's super frustrating cause I can't seem to finish my recording in this style of playing. I thought maybe it was certain keys on the keyboard but I tried an octave lower on the keys and the same result. Maybe there's something in the hidden features I don't have right? I hope it's not defective but I still have 20 days with my guitar center return policy if I need to exchange it.Any other style of playing seems to work just fine. Help or advice is greatly appreciated.
_DemonDan_
Re: Weird key response during legato key stroke
Post by _DemonDan_ » Fri Sep 25, 2015 11:48 am
Hi jrivera,
The key thing about Legato (depending on certain settings) is that the envelopes don't retrigger.
If your SUSTAIN levels for either the Filter or Amp EG are set to create silence over time, then your legato notes will eventually go silent.
If you don't think that's the problem send me a PM and I'll give you an address to email me the patch, so I can try it on my Sub Phatty.
jrivera
Post by jrivera » Fri Sep 25, 2015 2:19 pm
Thanks for the response Damon. I have my Sustain and release up pretty high, so I suppose this might be whats causing it.
Will definitely send you my patch, thanks!
stiiiiiiive
Post by stiiiiiiive » Sat Sep 26, 2015 5:34 am
Another track is that with legato enabled, the velocity-to-amp (resp. velocity-to-filter) parameter has the notes more or less loud (resp. bright) in a not so natural way. It works better in staccato, I find.
Space Lee
Post by Space Lee » Mon Sep 28, 2015 2:39 pm
_DemonDan_ wrote:Hi jrivera,
I also experience this phenomenon several times on different patches where the tone suddenly stops, even during the buildup of a slow attack or during the decay and sustain phase of a sound while playing legato. My opinion is that it's a bug. I really 'hoped' someone else would spot this same bug, and here we are.
Thanks for posting this, jrivera! Maybe someone from Moog will be so kind as to look into this?
Sub 37 Bob Moog Tribute Edition | Sub Phatty | Win10 pro 64bit | MOTU 828mk3 fw
jrivera
Post by jrivera » Tue Sep 29, 2015 11:24 pm
Yeah it seems to be something funky for sure. Although I did recently go in to the hidden parameters and set the Envelope Triggers to 'Multi' as opposed to 'Single' and this definitely helped a lot. It still happens every now and again but certainly much better than every other bar when playing Legato melodies. Maybe give that a try and see if helps you out as well?
_DemonDan_
Post by _DemonDan_ » Wed Sep 30, 2015 9:07 am
If you send me an example preset I can try it. If you don't, I can't.
Space Lee
Post by Space Lee » Fri Oct 02, 2015 12:09 pm
Dan, there's no use in sending you presets. It occurs on all presets, even the factory presets.
What's more, i even heard the same thing happening on the Sub37 of my friend!
Space Lee
Post by Space Lee » Fri Oct 23, 2015 12:10 pm
Is there anyone @ Moog with ideas on this one? :oops:
till
Post by till » Sat Oct 24, 2015 8:23 am
Wired things might happen if you created a MIDI loop. To check this, simply play the SubPhatty from the keyboard without USB or MIDI cables attached. Still the same problem?
Sequence:
Space Lee
Post by Space Lee » Sat Oct 24, 2015 10:57 am
till wrote:Wired things might happen if you created a MIDI loop. To check this, simply play the SubPhatty from the keyboard without USB or MIDI cables attached. Still the same problem?
There's no midi involved whatsoever...
till
Post by till » Sat Oct 24, 2015 11:38 am
Strange.
Sequence:
stiiiiiiive
Post by stiiiiiiive » Sat Oct 24, 2015 12:36 pm
Could this be due to a bad poychain setting while not even polychaining? That would be all the time, but hey I'm trying to help :)
Space Lee
Post by Space Lee » Fri Oct 30, 2015 2:03 pm
stiiiiiiive wrote:Could this be due to a bad poychain setting while not even polychaining? That would be all the time, but hey I'm trying to help :)
Thanks for the support Stiiiiiiive, but i never did any setting on that. It occurs out of the box...
Space Lee
Post by Space Lee » Wed Nov 11, 2015 8:28 am
Space Lee wrote:Is there anyone @ Moog with ideas on this one? :oops:
Seems like there's no one @Moog reading this forum anymore...?
