Hey all-
I recently plugged my Moog EP-3 expression pedal into my Sub37 and immediately noticed a sharp volume swing when increasing the volume (like super touchy brakes for those car enthusiasts . Is there a volume curve parameter that can adjust the 'smoothness' of the volume pedal?
Scott
Adjusting volume curve when using expression pedal
- _DemonDan_
Re: Adjusting volume curve when using expression pedal
A somewhat pricey solution is the CP-251, which would let you seriously dial in the behavior you want.
But you'd soon find many other uses for it as well. (I have two, I could easily find ways to use more;-)
_ _DemonDan_ _
The CP-251 is a gateway to madness, but the good kind of madness.
A bit overkill to use to control theatre on a £35 expression pedalImNotDedYet wrote:The CP-251 is a gateway to madness, but the good kind of madness.
Maybe there should be a menu choice where you can select the taper of the pedal by company and model like on the Nord Electro 4?
