It worked fine before, there's days it works well, then others it does this... Happens when FLStudio crashes for example.
I'll try to play a note or a arp, anything, any pattern - the sub plays maybe shortly for the first 1-2 seconds then stops for 10-15 seconds then plays for 2 then stops... Even if i keep the key down. It's kind of like an LFO or envelope issue but i can't see why it affects all the presets...
It's quite weird. I can turn on and off the sub or switch patterns but it wont stop doing this... I can't figure out what parameter or what is causing this issue...
If i turn off all my synths (OT, AR, Mininova), and after 1-2 reboots of the sub it comes back... Local control can be on or off.
What could cause this?
Sub plays then doesn't then plays then doesn't problem
- Bald Eagle
Re: Sub plays then doesn't then plays then doesn't problem
I have a similar problem with Sonar and the Sub37. Still don't know what exactly causes it but I can correct it using the INIT SETTINGS menu command. Perhaps the Subs Shift mode INITIALIZE PRESET command will help.
INITIALIZE PRESET
Engage Shift mode and press BANK 3, BANK 4, and PATCH 1. Press C# twice to reset all the Shift-mode parameters to their default settings.
My symptoms are at this thread ...
http://forum.moogmusic.com/viewtopic.ph ... 28#p138228
INITIALIZE PRESET
