Is it possible to record the position of the modwheel when i record a sequence on the sub37?
I thought that is was possible according to the manual but I can't figure out how to do it... (I don't hear the expected results when I play back te sequence...)
Record modwheel position in step time sequence?
Re: Record modwheel position in step time sequence?
you need also to set the programmable mod source = "SEQ MOD" ... it's not quite like it's playing back the mod wheel directly, more like the mod wheel is a data-entry device for recording a generic mod-value per step. You can then assign that mod-value per step to all sorts of things on playback.
Thanks for your answer Amos, I'll give it a try tonight!
