Hi, does anyone know if it is possible to manually set the VCA level anywhere. It seems what is considered VCA level always is at max value since modulation only works when applying negative modulation. The way works now i am not able to figure out how to for instance do amplitude modulation using KB reset with the square LFO, and expecting the note to start at high amplitude.
Am i missing something here perhaps?
Sub 37 VCA Level as modulation destination?
Re: Sub 37 VCA Level as modulation destination?
I was wondering the same a couple of weeks ago, but I think it is supposed to work the way it does. However, I'm not completely sure...
Would like to hear some expert opinion
