Hey guys! Im new here and the little phatty is my first moog.
Was wondering if someone could help me with this bass sound.
https://www.youtube.com/watch?v=AMbupnr-arQ
I have no much idea of how to make it.
Thank you in advance guys.
Help with sound design
Re: Help with sound design
I know this isn't much help but when I try to copy sounds I always start in reverse. I.e. Set your envelopes so that they match the sound you are trying to copy, then do the same with the filter. You should be able to set cutoff and resonance and env depth pretty close to what you need. You're after the sound of the filter at this point. When you have those set then move on to the oscillators. From the brief listen to the track it sounds like square waves on my tiny speakers. Not got headphones with me otherwise could hear it better and give you more advise.
Hope this helps.
Hope this helps.
Moog Sub 37, DSI Mopho KB, Korg ms20 mini, Korg M50, Korg Karma, Yamaha Motif Xf6, Yamaha DX7, Novation K Station, Waldorf Blofeld, Siel DK80, cyclone analogic tt 303
