Hi, since the Sub-phatty Moog seems to quit oscillator 2 as a modulation source
Now I was looking for it in the Sub 37´s manual and found that you have a modulation menu page where you can choose "oscillator 1/2 pitch" as a modulation source to use in the filter eg/PGM setting
So, that "oscillator pitch" means the audio output of an oscillator can be used for high audio rate modulations?
I hope so
Sub 37 Oscillators as modulators
Re: Sub 37 Oscillators as modulators
short answer: no. the vco's output signals are not available as modulation sources in the s37.
'osc 1/2 pitch' stands for 'osc 1/2 pitch cv' - the internal (virtual, i suppose) cv signals controlling the pitch of osc 1 and 2.
i dimly recall that this has been covered elsewhere, probably somewhere im the sub 37 - questions thread.
bleep...bartleby wrote:short answer: no. the vco's output signals are not available as modulation sources in the s37.
well, the lfos can go really fast, and they can track the kb. so they should be usable in similar ways as the vcos...
