It's not really a reboot, but I couldn't think of a better word at that moment.mmarsh100 wrote:The only time the machine rebooted for me was after the main sysex file.
The panel ones did not reboot my machine.
Let's just say it loses the USB connection after some of those steps.
So always check after each send that your librarian is still connected to the Sub 37 via USB.
I'd bet against it, especially since they were zipped.mmarsh100 wrote:I wonder if I have corrupt sysex files?
Start from FINE TUNE and CUTOFF all the way counterclockwise and PITCH all the way up, then power on.mmarsh100 wrote:I will try to re-download and do the whole shebang tonight...
Wait a bit. Make sure your librarian sees the Sub 37 again. If it doesn't, do an ordinary power cycle and try to find the USB again after 15 seconds.
Then, send the Main file.
Wait a bit after the Display screen is normal again. Make sure your librarian sees the Sub 37 again. If it doesn't, do an ordinary power cycle and try to find the USB again after 15 seconds.
Now send the Panel Erase file.
Send the Panel file.
Wait a bit after the LEDs are normal again. Make sure your librarian sees the Sub 37 again. If it doesn't, do an ordinary power cycle and try to find the USB again after 15 seconds.
Send the Presets file. As soon as those are sent you can send the Tunings file.
Note: Your Sub 37 will be left in the Slendro tuning scale.
Either:
1) Go to GLOBAL, go into the TUNING SCALES sub menu, and scroll all the way to the left to see 12 T Equal Temp.
or
2) Go to GLOBAL, go into the INIT SETTINGS >>> sub menu, and hold SAVE for 5 seconds.
