Sub 37 Feature Request....
Re: Sub 37 Feature Request....
My request is quite simple:
>> Moog, please keep the natural wood sides on the standard edition!
Plastic or black stained wood it definitely NOT Moogish.
And ash wood sides on my SUB 37 wood match my Etherwave Plus...
It would be nice to have the ability to load my Sub Phatty patches in to the Sub 37.
I also very much like having the extra headroom on the Sub Phatty mixer to slightly push the level up to 12. Would be nice to see this reflected on the Sub 37.
If I could request one thing and one thing only it would be to "fix" the continuously variable oscillators such that they don't have that hard switch between saw and square. Don't really see any use for it and it sounds like poo when you do osc wave sweeps.
Request two would be real analog envelopes. I would give up the looping and time modes for a little more character. That's not really possible, though, since the synth engine is to remain the same.
Belay that request, as Amos has reiterated that it is normal behavior for all new Moog oscs. I think it gets accentuated by the gain architecture and extra highs on the Sub. Interestingly, my osc 1 has it more pronounced than osc 2.
Ok, I just thought of a feature that might actually be doable. Since it's going to have two LFOs, one (or both) could have LFO Rate as a modulation destination. All kinds of wacky fun could be cooked up with this.
- _DemonDan_
This only fulfills some of your requests but...///OSS wrote:MOOG PLEASE ADD MY Ultimate Wants!
Arp/Step to Pitch/Filter/VCA/Mod destinations in a submenu
Both Arp and Step already can modulate the Pitch and Filter Cutoff.
The Arp is automatically connected to Pitch, and Arp might be able to be sent to Filter Cutoff via the Filter's Key Tracking knob.
And MOD 1 & 2 (which have Step) both have dedicated depth knobs for Pitch and Filter Cutoff.
Maybe "VCA" could be one of the "PGM" destinations for MOD 1&2.
Maybe "Arp/Kybd" could be one of the "PGM" Sources for MOD 1 & 2.
_ _DemonDan_ _
I hear ya. But the main reason for my request is to assign the arp or step to the filter alone for example. To play an independent melody with precise looped stepped filter tweaks. Or send to VCA only for interesting volume looping shapes. Either without affecting pitch. Or just to send it to VCO 2 only so that you could do some crazy stepped sync or FM effects, mixed with a stable key melody from VCO 1... Droolz_DemonDan_ wrote:This only fulfills some of your requests but...///OSS wrote:MOOG PLEASE ADD MY Ultimate Wants!
Little Phatty Stage #0042 - OS2.0 | CP-251 | MF-107 FreqBox | MF-102 Ring | MF-105B Bass MuRF
- stiiiiiiive
IIRC, I saw that was possible in the 22 minutes demo...kingfriday wrote:Ok, I just thought of a feature that might actually be doable. Since it's going to have two LFOs, one (or both) could have LFO Rate as a modulation destination. All kinds of wacky fun could be cooked up with this.
It would also be rad if one of the LFOs was independent of the mod wheel, or could at least be optionally decoupled from it.
- El Toxyque
Hello everybody!!!,
This is my first post!
What I'd like to see in my new SUB37 is "custom CV connections".
I mean that the Cv connections are patchable via software so that I can decide what the 3 Cv and the gate connections do.
For example in my first preset connection 1 is VCO2 out, connection 2 is Filter CV in, connection 3 is Envelope 1 out and connection 4 is arpeggiator gate out.
And I can change the patch as I want.
or better instead of the the four connections that are already there I would like a d-sub connector with a little break out panel with 8 jacks (as above I can decide what the jacks do via software) and that maybe could save some space for a midi through connector.
HUGE +1. It seems like many of us will be upgrading from the Sub Phatty to the Sub 37, so I hope this is possible somehow. I've spent a lot of time fine-tuning the presets I used on my SP for my band and it would be nice to be able to just transfer them over. It seems like the Sub 37 has every feature that the SP does (in addition to a whole lot more), so it appears like this would be possible.Gitzo73 wrote:It would be nice to have the ability to load my Sub Phatty patches in to the Sub 37.
Also, do we know if it will be possible to set LFO time by BPM? I use my synths to play subby bass lines for my band and we often add LFO that's timed with the tempo of the song. It would be great to be able to set LFO to X BPM and be done with it.
- stiiiiiiive
The Little Phatty and Sub Phatty do it, don't they? At least they have MIDI sync'able LFOs.alpcohen wrote:Also, do we know if it will be possible to set LFO time by BPM? I use my synths to play subby bass lines for my band and we often add LFO that's timed with the tempo of the song. It would be great to be able to set LFO to X BPM and be done with it.
- _DemonDan_
Hi alpcohen,alpcohen wrote:Also, do we know if it will be possible to set LFO time by BPM? It would be great to be able to set LFO to X BPM and be done with it.
If you look at the MOD 1 and MOD 2 panel of the SUB 37, you will see a "SYNC" button on each.
This will allow the LFOs to track various divisions of the MIDI Clock.
How do you change the Divisions of the MIDI Clock?
Look at the base of each LFO Rate and you'll see that there are Sync Division hashmarks that, presumably, will have the same divisions found in other current Moog products.
I believe that the loopable VCF and VCA Envelopes will also be able to be Sync'd to MIDI Clock, and of course, so will the Arpeggiator. That's a lotta' clock!
{EDIT} Although you can't see it in this picture, the Arpeggiator also has a SYNC button as well as both BPM and SYNC markings on the RATE dial. Given that there's an LCD display, it's likely that you will be able to dial in BPM with one decimal place for 10ths of a BPM like you can in the Little Phatty. {/EDIT}
Hope this helps,
_ _DemonDan_ _
I don't think i am alone in wanting a tap-tempo button right on the front panel.
MOOG: micro/sub/37/M32/DFAM/105m/MF delay/MF trem
