Design a cheat sheet for Sub Phatty hidden parameters
Everything Sub.
dswo
Post by dswo » Wed Mar 13, 2013 9:23 am
The manual for the new Sub Phatty is now available online: http://www.moogmusic.com/products/phatt ... nloads-tab. There's a lot to be excited about, including some new envelope features that weren't available on the prototypes. But learning them will be tricky, since they aren't labeled on the panel and there's no display.
Is there someone who could design a double-sided cheat sheet? The way I envision it, side 1 would summarize pp. 26-38 from the manual ("Additional Hidden Parameters in Shift Mode"). I don't know how to fit all of that on one page, but surely the spirit of Edward Tufte is abroad somewhere. Side 2 would be a line-drawing of the front panel, labeled to show what each knob and button does in shift mode (pp. 23-25 in the manual). Cf. Bob Borries' images here: http://www.muffwiggler.com/forum/viewto ... 53#1063453. A photo, such as Borries used, would be less legible than a line drawing, but you get the idea.
David Wilson-Okamura
Re: Design a cheat sheet for Sub Phatty hidden parameters
Post by EricK » Wed Mar 13, 2013 9:58 am
A software editor would probably eliminate the need for cheat sheets. It doesn't seem like it would be too hard to learn just by practicing the parameters you want to adjust the most.
Maybe they could go back to the old overlay method?
monokit
Post by monokit » Fri Mar 15, 2013 3:23 pm
If those setting will be saved with a preset, why not use one preset bank with your top 4 hidden funtion settings?
Amos
Post by Amos » Fri Apr 05, 2013 2:53 pm
Here is a cheat sheet I made; I hope it helps!
In very-much-related news, the editor is shaping up nicely, and will make all parameters easy to see and edit all at once.
Until then, try this pdf:
http://www.moogconnect.net/downloads/ph ... c_v1_1.pdf
cheers,
Amos
dswo
Post by dswo » Fri Apr 05, 2013 3:05 pm
Thank you, Amos. EricK's right: most of us will learn our favorite parameters without trying. But I want to stretch myself, and this will be a real help.
Yours gratefully,
David
mico
Post by mico » Sat Apr 06, 2013 5:55 pm
Amos wrote:Here is a cheat sheet I made; I hope it helps!
cheers,
Amos
Aftertouch Scale, eh? :D
Moog Sub 37 (#0133), Ibanez M80M, & Doomy Bow
MF-102 • MF-103 • MF-105m • KE Kommander • MHI B:a (Germ. w/EQ mod) • Strymon Timeline
Previous: Model D, Taurus, Taurus III, Little Phatty SE II (Solar Edition w/CV Out mod), Sub Phatty
Amos
Post by Amos » Sat Apr 06, 2013 8:55 pm
mico wrote: Aftertouch Scale, eh? :D
responds to MIDI Aftertouch.
dswo
Post by dswo » Sun Apr 07, 2013 12:11 am
Amos wrote:responds to MIDI Aftertouch.
This would have been my first request. Thank you, Amos.
Howard Scarr
Post by Howard Scarr » Sun Apr 07, 2013 7:24 am
Amos: In the cheat sheet, "GATED GLIDE" (top row) and "EG DECAY SPEED" (2nd row) appear to be duplicates of their neighbors.
Amos
Post by Amos » Sun Apr 07, 2013 12:28 pm
Howard Scarr wrote:Amos: In the cheat sheet, "GATED GLIDE" (top row) and "EG DECAY SPEED" (2nd row) appear to be duplicates of their neighbors.
Well-spotted, sir! Thank you! I've fixed and re-uploaded the file (same link):
also note: "14 Bit CC Output" has only OFF and ON settings implemented in the current firmware.
The third "Filter/Freq Only" setting shown in the cheat sheet is to be implemented in future.
The idea is to provide a mode where only the most sonically-sensitive controls send 14-bit MIDI, so as to reduce the overall density of MIDI output versus full-on 14 bit mode.
This was a Minitaur user request, so I thought I'd implement something similar on both instruments.
Voltor07
Post by Voltor07 » Mon Apr 08, 2013 9:25 pm
Amos
THE NUMBER OF THE BEAST! Sorry, I had to. :lol:
dswo
Post by dswo » Thu Apr 11, 2013 5:19 pm
Latest version of the cheat sheet: http://www.moogconnect.net/downloads/ph ... v1_1_4.pdf.
furiousgreencloud
Post by furiousgreencloud » Sun Apr 27, 2014 5:24 pm
Here is a Compact Hidden Function Cheat Sheet for the Sub Phatty, (Firmware Version 2.0)
http://furiousgreencloud.com/dl/pub/moo ... ctions.pdf
Please Enjoy.
I enjoy my Sub Phatty, but In my opinion, Moog is relying too much on it's legacy/brand rather than innovation. So what we get is endless variations and subpar references to the mini moog. Moog the company treats the the mini moog as the golden egg standard laying that goose that if they make something better would, i feel they think, be come redundant. :/
Come one guys go for it. There are so many other synthesis methods to play with!
Last edited by furiousgreencloud on Tue Apr 29, 2014 1:01 pm, edited 1 time in total.
dswo
Post by dswo » Sun Apr 27, 2014 5:32 pm
furiousgreencloud wrote:Here is a Compact Hidden Function Cheat Sheet for the Sub Phatty, (Firmware Version 2.0)
Thank you, furious.
