Moog Music Forum
Share Ideas and Pass the word
Vst Editor and Fl Studio not working
Little Phatty • Slim Phatty • Sub Phatty • Sub 37
Postby marksome » Sat Jan 12, 2013 8:14 pm
Hi there
Im trying to make the vst editor work in Fl Studio, but it seems that im not able to somehow.
Also the standalone is not working...
Im using usb connection...
Do somebody knows how to set it up proparly?? please help!
Thank you
marksome
Re: Vst Editor and Fl Studio not working
Postby onetruesaxon » Fri Mar 29, 2013 10:04 am
Hi there, did you have any luck. I'm having the same problem. I tryed following the advise from somewhere else on the forum but stil no joy
onetruesaxon
Postby funkerstronic » Tue May 28, 2013 12:53 am
Midi Setup: Send 14 Bit: Off / Send CCs: All Ccs / Midi In : USB Midi Out USB
Sart the editor---> open setup : Set both to Little Phatty on the Midi Ports & Set the right Midi channel so it must work in hte standalone version. :wink:
funkerstronic
Return to The Phatty Forum
Who is online
Users browsing this forum: CommonCrawl [Bot], Google [Bot] and 1 guest
