First off, just want to thank Moog for putting in the LFO retrigger with gate mode. This is an awesome feature that I didn't see in the manual but really was trying to do and boom there it is in the advanced presets. Must've been a 3.1 OS feature.
Anyways now I am trying to control the VCA with the LFO to create a tremolo type effect. It looks like this might not be possible as I don't see it anywhere in the manual, but it seems to be something that should be there. Is it hidden somewhere?
Let me mention that I did just get a Moog Ringmod and though I haven't played with it yet, I figure that I could drive the VolumeCV input with the Ringmod's LFO to get tremolo or just use the Ringmod itself as a tremolo. But I'd really like to be able to patch it within the Phatty and free up the ringmod for other stuff.
Thanks,
AnchovyD
Can LFO Modulate the VCA on the Phatty?
Re: Can LFO Modulate the VCA on the Phatty?
I believe the answer to your question is: No.
If Your LP has a CV Out Mod (which You should really consider you can patch Mod Out to Volume out, I'll try this when I get home and let You know if it works. You may need a CP-251 to set the Offset of the volume CV so You'll get desired volume with tremolo.
