Hi, tthere! I have set up my sweet moog and I have the audio in and moog working as a midi controller but i would like now the moog to play back the midi once i correct it in the DAW(ableton). (so that moog will play the midi and I can record the audio in ableton. and so that i can add the appregiator in the DAW and moog will play the midi with the DAW's appregiator - is that even possible??)
Any help would be great!
S xx
How to make the phatty play back the midi setup in the DAW?
Re: How to make the phatty play back the midi setup in the D
just send the midi track to your Phatty by selecting it in the 'MIDI to' section of track's settings
check the screenshot
you may notice that audio track monitoring is set to OFF
this setting enables Ableton Live's delay compensation and you record the audio (almost) without latency
Also you may need to set some settings in the Preferences menu / MIDI-Sync tab
You need to enable TRACK and SYNC for all MIDI ports you want to use to play midi tracks
Best regards, Ruslan Tagirov.
Toyz: MBPro+Live 9.x+LogicProX, Moog: LP StageII/Sub37/Grandmother/MF-104m/MG-105m, Nord: Stage2 SW73/ModularG2Engine, Roland: MC909/TR-8, Korg: MS-20, R-3, OTO: Bisquit/BIM, etc.
When you say... play back MIDI... Do you mean you want your DAW to act as a sequencer? Because MIDI is more like a control signal being sent rather than a note being played. Anyway, I would love if another Pro Tools user would help me out with this as well. I also have been trying for months to get help with sending MIDI Clock to the phatty so that it is synced to the BPM of the PT session. Pics like the above only with Pro Tools would help immensely.
Oh god Ruslan you have made my life complete today!!! THANK YOU !!! xxx
So I'm basically trying to do the same thing with ableton and I can't get it to work. I am using a DIGI 003 Rack as my interface. I have my LP plugged in via USB... Nothing. I set it up with all of the settings you used in those screen shots. I'm not getting any audio at all. Can someone help me out?
Ok, so now I am getting audio... But only after recording. It won't let me hear the audio before or while I record.
Dude, why did you say to switch monitor to off? That's why I wasn't getting audio! lol
well, you need some midi notes for moog to playgabestigmatic wrote:So I'm basically trying to do the same thing with ableton and I can't get it to work. I am using a DIGI 003 Rack as my interface. I have my LP plugged in via USB... Nothing. I set it up with all of the settings you used in those screen shots. I'm not getting any audio at all. Can someone help me out?
just press ARM button in the Moog midi track and record the midi clip,
or create the midi clip (menu Create->Insert Midi Clip) and then draw some notes in the clip
then press play on a clip
if you don't want to record, just want to play - set Monitor to IN in the midi track, and the Ableton Live! will send midi data it receives from the midi input to the Phatty.
Also, you might read the Ableton Live manual, especially 'Live Concepts' and 'Editing MIDI Notes and Velocities' chapters )
