Hi all guys!
Well, Lp is my first analogic synthesizer so i probably miss many things...
My question is about using a little bit detuned oscillators with some overload(witout sync), i get a very strange and quite harsh oscillation in the sound, especially with high pitch notes. Here is a little audio sample i ve done with cubase after more then 1 hour of warm up: http://www.sendspace.com/file/z6ivi6
Is this a normal thing or probably i am missing something? Is not possible to combine detuning with overloading? a re-calibration of lp will help for the stability between oscillators?
thanks in advance for any help!
detuned oscillators + overload
Re: detuned oscillators + overload
yes it is normal.
it is an interference between two sounds of slightly different frequencies (osc1 and osc2 in your case)
was i pushed or did i fall ?
Remember you can adjust the frequency of OSC 2 if you don't like the rate of beating, but only after it's warmed up properly otherwise you'll have to re-adjust again.
Two Slim Phatties 313 and 354- DSI Tetra - DotCom System - Korg Poly 800 - Yamaha DX27 & RS7000 + Matching Moog Pocket Protectors
oh ok, so i ve to adjust frequency as i supposed. Thank you guys!
yes , you could do that. or you could try to find detuned sound you like, and than enjoy it. what ever suits you
