Hello,
I tried setting my LFO to the settings in the instruction manual to get a simple vibrato by using the mod wheel. I set the source as a triangle wave, the destination as pitch, the amount at about 10 o'clock, and the rate to about 11 o'clock. However, whenever I play a note and move the mod wheel, the only modulation I hear is pitch bend. It basically just operates as a pitch bend wheel. Is there something I am missing or doing wrong?
It was able to work once, where I think I was able to adjust the LFO rate by tapping the LFO button to a particular speed. The LFO button was blinking. Only then could I get some sort of vibrato effect, but I do not know what I did to enable it.
Do you think there is something wrong with my LP? Any help would be much appreciated. Thank you very much!
Is my LFO broken??
Re: Is my LFO broken??
So you're sending the LFO destination to "pitch" and it's the "pitch" that's modulating? Sounds like it works fine to me?
Dom Kane
DJ | Producer | Engineer
Sound designer for Moog (Little Phatty + Slim Phatty), FXpansion (D-CAM), Steve Duda & Deadmau5 (Nerve)
http://www.facebook.com/domkane
Yeah but I'm trying to get the vibrato effect, and it's not doing a vibrato, it's just acting like the pitch bend wheel. The manual said those settings would do a vibrato effect.
do you mean sliding the wheel up moves the pitch up and keeps it there? or does it wobble up and down? If it wobbles up and down, then this is vibrato (modulating pitch).
Dom Kane
Sliding the wheel up moves the pitch up and keeps it there, it doesn't wobble. Basically I just want to know how to set up a vibrato effect through the mod wheel, but the instructions in the manual didn't work.
What did you select as the source?
Make sure you use a waveform for that, typical choice is the triangle waveform for vibrato.
It sounds like your LFO is trying to sync with a Midi device. Make sure the LFO source is set to internal.
Little Phatty Stage II, Rogue, Cp-251, Soldering Iron
Thank you very much! Is this done through the "PROGRAM CHANGE SEND/RECEIVE" menu in the master menu?Benjamin AM wrote:It sounds like your LFO is trying to sync with a Midi device. Make sure the LFO source is set to internal.
You mention Tap Tempo as if it's a feature you are unaware of. It is explained in detail in the manual page 23.thesauce wrote:Hello,
To use the mod wheel to adjust the LFO rate make sure LFO SYNC is set to INTERNAL. (Master Mode menu #3 - Manual page 25).
Yup that did it!
