Dear All,
I have a Theremini.
I bought a Kenton USB MIDI host
I connect to Midi Out my Roland U220 expander and each instrument is set with a different midi chanel.
I tested with EWI and configure it to test each chanel. Ok, the U220 is working with the Kenton.
So, i connected the Theremini USB connector to the USB of the Kenton.
By default, on the setup of Theremini, nothing go out on the U220.
I enter to the Theremini setup, and try some configuration.
But i didn't find good configuration
Can you please help me to parameter the Theremini to be able to use sound from my u220?
Thanks for your help
Theremini USB Midi Expander U220 Roland
Re: Theremini USB Midi Expander U220 Roland
Unfortunately the mode of transfer of notes in the Theremini is not working. Maybe it will be implemented in future firmware versions. Available only send messages of type CC. as a variant it is possible to use the Sonuus G2M device that converts any audio signal into MIDI notes.
By the way I want to ask the question as to the owner of the Theremini: does You have the function of "Theremin mode ON" advanced settings from the last firmware? I wrote a message in the forum about this, but have not yet received a response. in my experience it does not work on some copies of the Theremini...
Good luck in everything! Valery.
