Hi All,
I'm wondering if it's possible to use a clock pulse to tempo-sync the MF104M delay pedals. That would be super helpful (as opposed to MIDI sync) for working with a modular setup.
CV tempo sync for MF delays
Re: CV tempo sync for MF delays
It's been discussed to the nines, and no you can't. You need to supply the time CV in with a constant voltage.
Maybe with the 104M there is a way to mod the tap switch into a tap CV input but I don't know...
Bummer! But thanks for the reply.
- MoltenVoltage
You can sync them to MIDI clock using CTL-Sync.
http://www.moltenvoltage.com/products/C ... ltage.html
We also make a MIDI to CV pedal (CV-Sync) that could sync the rest of your modular devices.
http://www.moltenvoltage.com/products/C ... nizer.html
Kind of a roundabout way to get you where you want to go, but it would work.
.:. Bill
.:. Bill
Brilliant design! Thanks for bringing it to our attention and welcome to the Forum.
Stephen
Stephen
This is not a solution to the OPs request & you are showing a major lack of knowledge for implentation of your product.
The delay - any stock Moog delay - WILL NOT respond to CV clock pulses to set the delay time. This product does not offer a constant voltage solution where pulses are interpreted as the calibrated CV / time.
Did Moog agree to your advertizing?
Edit: Or am I showing a lack of understanding of the OPs request?
- latigid on
I have a Roland SBX-10 that will read clicks and generate a MIDI clock. They are no longer made, but you might be able to find a used one.
Wow, it's a lot more complicated than I originally thought. Thanks for the mini-lesson!latigid on wrote:OP might want to read this thread on MW:
http://www.muffwiggler.com/forum/viewtopic.php?t=99172
Reminds me of why I freekin' hate MIDI.
Stephen
- MoltenVoltage
I thought OP wanted to sync his MIDI-enabled MF delay to his modular setup, and CV-Sync would be a possible solution.Alien8 wrote:am I showing a lack of understanding of the OPs request?
Syncing to MIDI Clock has a distinct advantage over CV. Because it updates 24 times per quarter note, gear can react to a change in tempo much more quickly.
.:. Bill
- latigid on
Dear OP,
What modular standard are you using? You can get a Doepfer A-192-1 or A-192-2 (CV-MIDI converter), I think the latter might be easier to set up.
Run a quarter note clock into the 192 CVC, as long as it's below 12 V you should be fine. Then use the learn function to assign CC114 to it. Patch the MIDI out into the MIDI in on the MF-104. The clock operates the MIDI tap tempo function as any value of CC114 (or alternatively >63 of CC115).
Hope that works, you could also whip something up very simply with Arduino or a simple MIDIbox 8-bit core module.
