Hi everyone, I am trying to use a Source Audio Hot Hand as an expression source for my MF-107, but I have found that the Hot Hand's sweep range is diminished significantly when using it with the MF-107. I suspect this is due to mismatched pot values. Therefore, I need to mod one or the other so that I have an effective sweep range with the Hot Hand. Since I know neither the pot values of the Hot Hand or the Moogerfooger, I guess finding those would be a start.
Expression Device with Moogerfoogers
Re: Expression Device with Moogerfoogers
That would be a good start, yes. If you don't find the values online I could measure the resistance of my EP-2 later today.
Latest gigs
https://youtu.be/Fpvi7Jrq8DQ
http://youtu.be/owdKlBrUUKY
Minimoog Voyager EB & Minitaur + MF-101 + MF-103 + MF-104M + MF-107 + CP-251 + Minifooger Drive. MachineDrum UW + MonoMachine + Rickenbackerbass (-75) + Hagströmguitar (-75).
Thanks. According to Moog, the Moogerfoogers are designed to work with the EP-1 and I'm not sure if it has the same pot values as the EP-2.
I do believe the moogs are 100K ohms now.
