Can I Answer any MF-104M Questions?
_DemonDan_
Post by _DemonDan_ » Fri Jun 22, 2012 6:36 pm
Hi All,
I've had to keep my mouth shut until Moog announced it,
but I've been playing with a prototype of the MF-104M for
a while now, and have made an in-depth video as well as
14 guitar audio examples:
http://www.youtube.com/watch?v=74S-FgRdtoY
http://www.sweetwater.com/store/detail/MF104M/
In the mean time, can I answer any hands-on questions?
I've been banging on it pretty hard;-)
EMwhite
Re: Can I Answer any MF-104M Questions?
Post by EMwhite » Fri Jun 22, 2012 8:20 pm
I've got one. How different is it (internally) to that of the ClusterFlux.
I've seen comparisons here that detail the fact that the positive/negative infinity is unique to Flux, fair enough. And obviously longer delay times. The question is... IF the 104M Delay can be modded to allow very low ms delay times, could it produce some of what Flux can do?
There are other differences obviously and I'm really looking fwd to the spillover (I also wish I could get 1.4 sec or whatever). But it looks really nice. Looking fwd to it.
filosofem
Post by filosofem » Fri Jun 22, 2012 8:38 pm
Dan, how do you adjust the Feedback Insert Loop Gain?
Aaron Mulqueen: Moog Subsequent 37 - MF 104M
ZenHead
Post by ZenHead » Fri Jun 22, 2012 9:26 pm
How many will Moog make?
_DemonDan_
Post by _DemonDan_ » Fri Jun 22, 2012 10:22 pm
EMwhite wrote:How different is it (internally) to that of the ClusterFlux?
To be clear, I have only mild knowledge of circuit design and
great admiration for those who actually do it. I just program
and play with these things. So... I can only say that,
cosmetically and functionally, the MF-104M is a lot like a
ClusterFlux with a much longer delay time.
Can one be made to act like the other? To a degree. The Chorus
I was able to get from an MF-104M is beautiful and dreamy.
Even though it's monaural (unlike the stereo ClusterFlux), I kept
swearing that I was hearing stereo. I honestly had to check each
step of my system to be sure I wasn't somehow making the left
speaker different from the right speaker. That's just how 3D the
chorus sounds to my ears.
By trying various tricks to get the delay time as short as possible,
I felt that, at one point, I was closer to a Flange effect than a
Chorus effect. It was then that I really noticed not having both
positive and negative feedback.
Moog really took a chance and had enough faith in their customers
to offer the ability (via extreme Tap Tempo or CC#-only parameters)
to take the delay times waaay past their "legal" limits. Coloring
"outside the lines" can result in quite a few interesting artifacts but, I
would be seriously bummed if we were restricted only to the "safe zones".
As far as "modding" the 104M to the shorter delay times of the ClusterFlux:
The filtering of each pedal was specifically designed to provide the best
possible results. You can make either of them act somewhat like the
other, but each is CLEARLY optimized for their intended effects.
_DemonDan_
Post by _DemonDan_ » Fri Jun 22, 2012 10:28 pm
filosofem wrote:Dan, how do you adjust the Feedback Insert Loop Gain?
It now has to be done externally. In the case of Moogerfoogers,
the Drive and Output knobs will often suffice. If you have
something you'd like to insert that doesn't have In or Out gains,
you could use a mixer or sometimes even a simple attenuator
somewhere in the Send/Return path to get the desired amount
of gain. I still need to explore the Feedback Loop a lot more!
_DemonDan_
Post by _DemonDan_ » Fri Jun 22, 2012 10:32 pm
ZenHead wrote:How many will Moog make?
As is always the current limitation with Analog Delay quantities:
It totally depends on how many BBD chips they have.
I'll leave it to Moog Music to say how many that is.
Alien8
Post by Alien8 » Fri Jun 22, 2012 10:47 pm
Hi Dan, I was thinking you might have been given a demo!!
I have a few questions:
1) when switching between tempo's via the tap tempo switch, does the tempo rate change immediately, or can it be more of a gradual change - a la Leslie? Is this the slew setting in the manual?
2) can you "play" the delay feedback like in your clusterflux demo?
3) how controllable is the self oscillation? Is it as easy to let it linger in the background for example as the 104z?
4) more of an opinion question: if someone didn't use MIDI, and already has a 104z & 108, do you see value in switching units, or duplication? I guess I'm asking with respect to the the sound quality, manual playability etc. as I realize there are specific features that set the Z / SD / M apart like tap tempo etc.
Thanks!!
aaronharmon
Post by aaronharmon » Fri Jun 22, 2012 11:49 pm
I asked the rep at gearfest today and he said that he couldnt be sure because things could change based on availability of the parts but at this time they have enough to make less than 1000. That is a specific as he could or would get.
BHC303
Post by BHC303 » Sat Jun 23, 2012 2:15 am
Besides Midi how different is it from the 104z?
Is there anything that the z can do that this cant?
Thanks Dan
:mrgreen:
puzzlegob
Post by puzzlegob » Sat Jun 23, 2012 6:30 am
Thanks for starting this thread!
I've browsed the manual, and noticed that there is a slew rate parameter, and the delay time can be synced to MIDI clock....
I was wondering if this means that, for example, if a 16th note delay time is extended to a 1/4 note delay time, will the slew limiter smooth the transition, or does MIDI clock sync 'snap' the delay time immediately from one value to the next?
i.e. Does MIDI synced delay time override the slew limiter?
aaronharmon
Post by aaronharmon » Sat Jun 23, 2012 7:28 am
BHC303 wrote:Besides Midi how different is it from the 104z?
Thanks Dan
:mrgreen:
200 more msec of delay, thats it. The m throws the Z a beating in every other way.
EMwhite
Post by EMwhite » Sat Jun 23, 2012 9:38 am
I'd be curious to see if the basic BBD use/design is identical (same ICs being used) and that the 'short' delay sound is of higher quality (increased clocking). I'm not an electronics genius like many of the posters here so I'm not completely up to speed on how "increased headroom" translates to sound quality.
I'm coming from a Diamond ML2 which has slightly north of 600ms with no 'long' mode and the sound quality was stellar with a tilt EQ that could darken things off by rolling off highs. Interested to see how the Diamond and 104M compare sound-wise.
stiiiiiiive
Post by stiiiiiiive » Sat Jun 23, 2012 11:00 am
I only can speak about the MF-104z, but having heard some MemoryLane 2 demoes, the most obvious difference to me is the ML is much more "middy" -pun not intended haha- than the Moog which is as you may know darker.
_DemonDan_
Post by _DemonDan_ » Sat Jun 23, 2012 1:04 pm
Alien8 wrote:1) When switching between tempos via the Tap Tempo switch, does
Yup, that's precisely what the Slew Tempo Rate parameter is for.
It goes from instantaneous to a few seconds of slew.
Alien8 wrote:2) Can you "play" the delay feedback like in your ClusterFlux demo?
Yes, but the significantly longer delay times in the MF-104M means
that you're not hearing "pitched" feedback like on the ClusterFlux.
It's more of a rapid way to change delay times. Both units observe
the "1 octave = 2x Delay Time" formula.
Alien8 wrote:3) How controllable is the self oscillation? Is it as easy to let it linger
As an experiment, I fed an M and a Z the exact same source, matched
their gains and Delay Times as close as I could, and sent one to the left
speaker and one to the right.
In this test, I found that it was far easier to keep a delayed sound going
as a pad on the MF-104M than either of the two MF-104Zs that I had.
The MF-104Zs tended to get garbled or "clacky" over time while the
MF-104M just kept going and going.
Alien8 wrote:4) If someone didn't use MIDI, and already has a MF-104Z & an MF-108M,
In every case I personally preferred the MF-104M over the MF-104Z every time.
When I played a piano sample into both I was surprised at how much more the
first piano echo sounded "like a piano" on the MF-104M. Plus Spillover Mode,
Extreme Delay Times (with quirks), Tap Tempo, lower noise floor, and the
ability to create delicious Chorus effects with Echo make it a no-brainer. But
that's only my personal preference.
