It's looking good and getting better.Presumably upgrades will be available for early purchasers.
I expect it will be a couple of months before I'm ready to buy, but temptation is growing!
John
Voyager Ed/Lib available
The 1024 X 768 is a required resolution for the editor to see all windows in full size. However, the size of the windows also depends on FONT SIZE settings. The "default" windows setting is Small Font. If you use bigger fonts, editor windows may expand the windows to display captions beyond the 1024 horizontal resolution. In this case you may need to use higher screen resolution or change back the system fonts to the default setting.
I mean 1024 X 768!
As I explained, the window size not only depends on the screen resolution but also on Windows FONT setting.
To see all windows in full the requirements are:
1024 X 768 for SMALL FONT setting (normal size - Windows default)
1280 X 960 for LARGE FONT setting
To change Windows font size use DisplayProperty/Settings/Advanced
Moog Voyager Update 1.1 PC
Hi-
There is a new update available now for the PC version. Thanks to your suggestions we added few more features. Now browsing through presets in Voyager's bank or library displays switch/know/rotary positions:
Also using "Auto" option to update the editor when you manually turn knobs or flip switches is not needed anymore. We have mapped all CC data sent by Voyager to editor's control making it fully interactive with each other.
