What's the best way to connect my Voyager to my computer to use the Voyager Editor program? I've seen the Turtle Beach & Hosa MIDI to USB connector cables, is that the standard way? My computer has Firewire (4 pin nonpowered variety); is there a Firewire option?
You can probably tell that I know almost nothing about MIDI; thanks in advance for any advice on this topic.
David
Voyager to Computer Hardware Interface
I use the M-Audio Midisport 2x2. You'll need two midi cables as well; for an In and an Out. I think the Midisport is $50-60. You don't use the Firewire port. The Midisport uses USB. Now there might be other interfaces that use Firewire.
Mark Mahoney
http://www.reverbnation.com/markmahoney
www.cdbaby.com/cd/mmahoneympeck
www.cdbaby.com/cd/markmahoney
for this kind of data (sysex only) even the cheapest midi interface will do the job. There is no timing or multi outputs needed.
Sequence:
Sequence:
Also:
http://www.zzounds.com/item--MDOUNO
I use this for sysex transfers because I can't transfer with my MOTU 828mkII for some reason
Very easy to use, basically just plug in and play.
