Well, as the title says. I'm not capable of any sort of thought and can't find the manual. I just want to assign the filter decay to the pedal. How?
Sorry if I appear as an provocingly lazy s.o.b. Today is just one of tjose days when I want to play and can't think.
Brain meltdown. Want to assign pedal to filter decay.
Latest gigs
https://youtu.be/Fpvi7Jrq8DQ
http://youtu.be/owdKlBrUUKY
Minimoog Voyager EB & Minitaur + MF-101 + MF-103 + MF-104M + MF-107 + CP-251 + Minifooger Drive. MachineDrum UW + MonoMachine + Rickenbackerbass (-75) + Hagströmguitar (-75).
Re: Brain meltdown. Want to assign pedal to filter decay.
Enter EDIT menu
select item 5.4 POT MAPPING
select: SRC & DEST Map 1
set these values there:
SRC: MOD 2 (socket to connect pedal to in the Voyager's back)
Dest: Filter Decay
Direction: normal (longer decay when pedal is down)
Amount: 25%, 50%, or 100% according to your needs.
Please be sure to set the minimum filter decay on the panel.
Dest: Filter Decay
Sequence:
Sequence:
