Programming question
I have this patch on my Voyager, Growing Lead (factory). If I keep a key pressed down and press a lower key, it jumps to the new note but if instead I press a higher key it doesn't jump to the new note. Can anyone tell me why?
Re: Programming question
Go to Edit Mode, find "Keyboard Modes" and change it to "Last Key" (I'm pretty sure it's in "Lower Key" mode right now).
- fyvewytches
Check the "Keyboard Mode" settings.
hth
hth
Latest track, Dancing On The Ecliptic http://soundcloud.com/ianman/dancing-on ... iptic-demo
- thealien666
Keyboard mode can either be "Lower Key", "Higher Key", "Last Key", or "1 Key Only".
This is programmable per patch. This one, "Growing Lead", is obviously programmed with keyboard mode set to "Lower Key", which will give priority to the lowest key played.
You should also be aware of the "Trigger Mode", which offers "Single Trigger" or "Multi Trigger", which will select how the envelopes will behave. In single trigger mode, once a note has been depressed and is being held down, pressing another key will not re-trigger (re-open) the envelope.
A careful reading of the manual, in the "Edit Mode" section, will explain all this in detail.
Hope this helps.
Hope this helps.
Brilliant! Thanks for the explanation. Re manual my retailer still hasn't sent me one but it's true I should have scoured the PDF one! RTFM.
- thealien666
You're welcome.
Until you eventually receive your paperback copy, here's the link to the online one in pdf format (if you didn't have it already):
http://www.moogmusic.com/sites/default/ ... _combo.pdf
Thanks again. This synth is quite unbelievable! Starting to get to grips with using OSC 3 as modulation. So powerful. Such a well written manual.
There is also this "Voyager Training DVD" that has been uploaded to youtube featuring Brian Kehew:
http://www.youtube.com/watch?v=Bfe9bHhSMNk
- thealien666
This is a direct link to the playlist that includes all the 6 parts. Unfortunately, the audio quality is rather poor. But, hey, it's free.
http://www.youtube.com/watch?v=Bfe9bHhS ... 76E71BE6C6
