Volume envelope doesn't work
Benniczek
Post by Benniczek » Sat Apr 20, 2013 3:01 pm
Hi guys!
I got a Minimoog Voyager Old School about 2 months ago and it worked properly for the first 6 weeks. But then, one day and all of a sudden, when I switched it on, the volume envelope generator didn't work and I haven't found the cause yet. I can still set the sustain level (which has the same effect as the general volume knob) but changing the attack, decay and release settings doesn't do anything. The Voyager OS just does not react. The filter envelope generator and everything else works perfectly, though. As I said, I didn't put any strain on the Minimoog, it was always standing inside my room and wasn't exposed to any heat, cold or moisture so I don't have an idea what happened and why only the volume envelope broke. Can anyone help? Has anybody an idea what could be wrong and what I can do (beside from having it repaired by an expert)?
Thanks in advance,
Benniczek
muksys
Re: Volume envelope doesn't work
Post by muksys » Sat Apr 20, 2013 10:23 pm
Just for kicks have you tried setting one of the Mod Busses controller to the vol. env?
Try this:
Mod Bus 1
Source: ON/MOD2
Destination: Filter
Controller: VOL ENV
Amount: Noon or higher
Set the cutoff, spacing & Res to Noon. Set Amount To Filter to off (noon). Set the Vol Env Attach + Decay to 3 o'clock, sustain to 0. Release to any.
Is it new or did you buy it used? If used, did the previous owner buy the extended warranty? If so you can have it transferred to you (the standard warranty is non-transferable unfortunately). Chances are it will need to be sent in for repair.
Benniczek
Post by Benniczek » Sun Apr 21, 2013 5:54 am
Thanks for the reply!
I tried your settings and - again - the volume envelope doesn't have any impact, just the sustain works which, with your settings, works properly as cutoff but still there's no attack, decay or release. I bought the OS at Armen's Music Shop on ebay, so it's brand new.
muksys
Post by muksys » Sun Apr 21, 2013 10:28 pm
Ah, that's good it's new. Register it if you haven't already and call moog. This sounds like an issue that needs some official servicing. I'd also suggest the extended warranty eventually.
restlessboy
Post by restlessboy » Tue Jun 24, 2014 5:19 pm
I've got the exact same problem here. A D and R not working but S is fine. Did you ever get a solution?
Vsyevolod
Post by Vsyevolod » Tue Jun 24, 2014 5:33 pm
Our good friend Benniczek last visited this forum on 21 Apr 2013, so something tells me he won't be responding to your question.
A two post wonder, whisked off by the winds of the Interwebs...
Stephen
restlessboy
Post by restlessboy » Tue Jun 24, 2014 5:45 pm
Yeah, thought someone else might have an idea. Or you never know, maybe he subscribed to the topic?
I'm hoping this isn't a 'post it to the US' job. Anyone know if Moog has a dedicated tech support in the UK? :(
bichuelo
Post by bichuelo » Tue Nov 18, 2014 3:45 pm
Have you contacted Moog support yet? Mine had a very similar issue and an RMA was approved almost immediately.
http://audiotecna.info
Vsyevolod
Post by Vsyevolod » Fri Nov 21, 2014 4:23 pm
Always send an email to Moog. They are incredibly responsive and will get you back in good nick the easiest and cheapest way.
Stephen
