MF Ring Modulator + Voyager
Hi - dont have any experience of Ring Modulation (RM) but seen a used one for sale. So, will it give me much mileage with my Voyager + vx351. Is this pedal a one trick pony? Can't say that I really need another LFO..
I have this to listen to when I get home (cant listen to mp3s at work)
http://www.harmony-central.com/Reviews/ ... r/002.html
so this will give me an idea of what RM is all about..
Paul
London
www.punkdisco.co.uk : Getting Married? Need a [url=http://www.punkdisco.co.uk/Weddings.htm]reception band[/url]? New [url=http://www.punkdisco.co.uk/Music/DVDA.mp3]DVDA Track[/url]
London
the vibrato is nuts on the Ring Mod. There are moments of pure amazement at the gorgeousness of the vibrato (on a Rhodes, at least)...but it also works well w/certain organ type sounds I seem to conjure up on the Voyager.
Another thing is the wicked atonal type distortion. Its a very subtle pedal. Only for those who knowz... "Be patient" is what I'm learning about Moog gear. Their secret mojo gets revealed at the right moments... Its built real deep...appears simple, but is extremely versatile and rip-roarin!!!
Buy it from those fools who didn't have the patience or taste! That's what I did, it took me about 6 months to really dig into it...But once I found the vein, I was lead to more and more gold...
MPC3000, MF-101, 102, 103, 104Z, 105M, 108m, 107, CP-251, MINI MODEL D, OB-8, ALESIS A6, ARP ODYSSEY MK1, RHODES MK1
Hi - thanks for all the replies so far. It does look intriguing.
I listened to the audio clips last night and to be honest, these Ring Modulation clips sound a little like my least favourite effect: 'flanging'. Is this just because they have used the LFO to vary the amount, so you get a typical slow sine wave modulated flanger effect?
Also, regarding the Voyager, where do you guys put your Ring Mods? After the main outs or as an insert on the oscillators using the insert point (can't remember what the socket is called)?
Thanks again,
Thanks again,
Paul
London
London
"Also, regarding the Voyager, where do you guys put your Ring Mods? After the main outs or as an insert on the oscillators using the insert point (can't remember what the socket is called)?"
Back at home now.. The insert point is called "Mixer Out/Filter In".
Thanks,
Thanks,
Paul
London
London
I have a Ring Mod unit (not the MoogerFooger RM, though). With an extremely lowMarkM wrote:I like it a lot. One of the best effects is the vibrato it can produce.
carrier setting, I get corresponding low Amplitude Modulation (AKA tremelo), not vibrato.
Could it be that the effect you hear as vibrato is really tremelo?
Vibrato describes a slow pitch (frequency) modulation. The frequency of a 'natural sounding' vibrato is around 5 or 6 Hz. This is generally true for singers, guitarists, horn players, etc. While synth players can get any vibrato frequency they choose, program it too slow and it sounds 'sick', make it too fast and it sounds comical. Go faster still and you get into the realm of FM.soundhound123 wrote:i thought vibrato was amplitude modulatio, and tremelo was pitch modulation.
Tremelo, on the other hand, describes a slow amplitude modulation. The frequency of a natural sounding tremelo is somewhere in the range of 3-6 Hz. A lower frequency begins to sound less like a tremelo and more like a fade in/fade out effect. A higher frequency tends to sound 'synthetic'. Go higher still and you get into the realm of AM.
- Greg
Re: Post subject
Hello,
The mistaken reference to tremelo as vibrato goes back over thirty years.
Manufacturers of late sixties/early seventies vintage gear routinely, but mistakenly used the terms interchangeably.
Wurlitzer referred to the tremelo ckt of their 200/206 pianos as vibrato, Fender did the same with the suitcase Rhodes. In addition, some amplifier manufacturers also did the same with their guitar amps that featured the tremelo effect.
Regards,
LWG
Regards,
LWG
sorry. You're right. . .tremolo it is.
GregAE wrote:I have a Ring Mod unit (not the MoogerFooger RM, though). With an extremely lowMarkM wrote:I like it a lot. One of the best effects is the vibrato it can produce.
Mark Mahoney
http://www.reverbnation.com/markmahoney
www.cdbaby.com/cd/mmahoneympeck
www.cdbaby.com/cd/markmahoney
Re: Post subject
You're right! I remember reading that recently in "Guitar Effects Pedals - The Practical Handbook". Quoting from page 11:LWG wrote:... The mistaken reference to tremelo as vibrato goes back over thirty years.
"Fender was often guilty of mislabeling an amp 'vibrato' when the effect it carried was actually tremelo (conversely, Leo Fender also named his Strat's vibrato unit a 'tremelo arm')."
Small wonder people are confused about this...
Thanks for pointing this out, LWG!
- Greg
