Voyager pitch cv not scaling correctly.
n2design
Post by n2design » Sat Jan 12, 2013 8:19 pm
I am trying to control the voyager with an analog 4 cv out but my settings arent working right. Anyone have any idea why?
Here are my settings
Type = Pitch V/oct
Middle C = 3.00v
V/OCT = 1.00v
GovernorSilver
Re: Voyager pitch cv not scaling correctly.
Post by GovernorSilver » Sat Jan 12, 2013 9:32 pm
n2design wrote:I am trying to control the voyager with an analog 4 cv out but my settings arent working right. Anyone have any idea why?
Type = Pitch V/oct
Middle C = 3.00v
V/OCT = 1.00v
Shouldn't you set your A4 V/OCT to 0.93V or whatever the Voyager expects from the A4?
n2design
Post by n2design » Sat Jan 12, 2013 10:51 pm
.93 doesn't work well either. Note is not pitched and each octave isn't 12semitones.
GovernorSilver
Post by GovernorSilver » Sun Jan 13, 2013 2:13 am
n2design wrote:.93 doesn't work well either. Note is not pitched and each octave isn't 12semitones.
I didn't mean literally set the value to 0.93V. What I meant to say was you might have to use your ear to determine the proper setting. It could be 0.94V. Or 0.92V. Or 0.9378V.
sunny pedaal
Post by sunny pedaal » Wed Jan 16, 2013 12:01 pm
start by setting the first c / 0volt.
when that is tuned well, take c1 and adapt the midi/cv or controller signal so that c1 is tuned.
don't start on c3...
n2design
Post by n2design » Thu Jan 17, 2013 12:28 am
sunny pedaal wrote:start by setting the first c / 0volt.
Thanks for the tip!!
MC
Post by MC » Thu Jan 17, 2013 10:45 am
The Voyager output CV without CP-251 is 0.93V/oct.
The Voyager CV input is 1V/oct.
n2design
Post by n2design » Fri Jan 18, 2013 5:18 pm
MC wrote:The Voyager output CV without CP-251 is 0.93V/oct.
That's strange, Why did they make them different?
btw, turns out the a4 scaled correctly via cv @ 1.02v
GovernorSilver
Post by GovernorSilver » Sat Jan 19, 2013 1:33 pm
Looks like a CP-251 is a "must-have" if I ever want to play an external oscillator (eg. Make Noise DPO, Malekko Anti-Oscillator, etc.) in-tune from the Voyager keyboard.
Congrats n2design on solving your issue
