Moog Music Forum
Share Ideas and Pass the word
smd or hole thru
Tips and techniques for the Voyager
smd or hole thru
Postby sunny pedaal » Mon Nov 26, 2012 12:52 pm
is the voyager smd or holethru soldered ?
( hope the last , in case repairs should be made in future )
and is there a difference in b.e. signature series and/or later versions including the latest 24k gold plated version ?
sunny pedaal
Re: smd or hole thru
Postby MC » Mon Nov 26, 2012 3:37 pm
sunny pedaal wrote:and is there a difference in b.e. signature series and/or later versions including the latest 24k gold plated version ?
Electronic wise, only the computer boards differ depending if you have one bank of 128 patches (originally installed on SE) or seven banks. Early Voyagers like the SE did not have filter glide or other improvements. Early Vgers also had IC sockets for all the ICs.
Analog board is thruhole
Original computer board is thruhole, revised one (with 7 banks) is SMD.
MC
Postby sunny pedaal » Mon Nov 26, 2012 3:55 pm
thank you , so upgrading my signature in that respect degraded the computerboard...
glad to hear the soundboard is thruhole, good for futureservice
sunny pedaal
Postby EMwhite » Tue Nov 27, 2012 8:14 pm
Have a look here at our good friend, Till Kopper's web site and you'll see the Voyager in all of it's through-hole goodness; then click on the link towards the top of the page for the 'upgraded' SMT digital board.
http://till-kopper.de/voyager.html
Moog Voyager Old School, LP Tribute, Taurus 3, Opus 3; Ob: Matrix 1000 and SEMs; Blofeld; too much modular stuffis; Kurzweil 250; Hammond M3; Fender '75 Jazz, Tony Franklin Fretless Monster; MusicMan Stingray; Mesa Amps; MF101,102,104M,105M,MP201
EMwhite
Postby EMwhite » Tue Nov 27, 2012 10:47 pm
And then, of course there is this series of photos posted from some 3 years ago (including the Old School and the obvious vacancy of any digital bd).
viewtopic.php?p=44085
EMwhite
Postby sunny pedaal » Wed Nov 28, 2012 6:14 pm
thank you very much
very nice to see.
i wonder, why did they change to smd , nothing else available anymore ?
sunny pedaal
Postby Tibbon » Sun Dec 02, 2012 12:04 am
Keep in mind that SMD is absolutely repairable. It isn't hard even with a standard bench iron. With hot air rework, it becomes easier than through hole for some stuff.
Signature #144
Tibbon
Postby sunny pedaal » Sun Dec 02, 2012 5:43 am
most professional synth-repairders in the netherlands don't agree on the easiness of repairing smd. to be more specific they state they don't repair it. ( or very limited and with great dislike, holethru is always greatly preferred ). maybe the future younger generation will make less problems of it...hope so
sunny pedaal
Postby RL » Sun Dec 02, 2012 6:37 am
BTW ... it's also possible to upgrade old digital boards. When you're living in the EU you can send the board to lintronics.de for the upgrade.
Have fun,
Rudi
RL
Postby Voltor07 » Sun Dec 02, 2012 3:36 pm
sunny pedaal wrote:most professional synth-repairders in the netherlands don't agree on the easiness of repairing smd. to be more specific they state they don't repair it. ( or very limited and with great dislike, holethru is always greatly preferred ). maybe the future younger generation will make less problems of it...hope so
There's only so much one can repair on an SMD board. Many of these boards are multi layer. A dual layer board is no problem to fix, but a three, four, or five layer board is non-repairable, unless a dead component is on one of the outer surfaces.
Little Phatty Amos Gaynes Signature Edition, CP-251, MF-102&103, EHX #1 Echo, Pyle PTA1000, Miracle Piano, Taurus III #0030, Walking Stick ribbon controller, Voltor box V.1.0&2.0, Synthutron.com, Lowrey Teenie Genie.
Voltor07
Postby thealien666 » Sun Dec 02, 2012 4:01 pm
Voltor07 wrote:...A dual layer board is no problem to fix, but a three, four, or five layer board is non-repairable, unless a dead component is on one of the outer surfaces.
BTW, on multi-layered boards, there are no components on inside layers (to my knowledge). Only traces that connect to different parts of the the two surface layers where SMD components are located.
The main reason for some technicians being reluctant to fix SMD devices, is the specialized tooling required and the high precision also required in manipulation. But most importantly,the increased cost (mostly in hourly rate) in fixing these. And also the occasional costlier custom designed replacement parts (PLA and mask rom DSP) in hybrid systems. It's a fact of life that, what synth companies save in design and manufacturing costs by using SMD, will be lost in trying to repair such technology. It's, more often than not, less costly to simply replace a whole board than trying to diagnose and repair it, especially complex multi-layer ones.
Sometimes, using JTAG, it's possible to quickly and easily find faults on SMD multi-layer boards (mostly bad solder joints or broken traces or interconnect between layers), but again that requires specialized diagnostic equipment and documentation.
Well, it has five forward speeds..What, you mean electronic gear ? Got cruise control.. mmh what ? Oh, you mean musical equipment gear ? It has a nice sound system too.
http://www.youtube.com/alainhubert
http://www.soundcloud.com/thealien666
thealien666
Postby sunny pedaal » Mon Dec 03, 2012 4:21 am
as long as spareboards are available it might be no problem. ( with the alesis-a6 b.e. it might become a problem soon )
for future, it might be my model-d better stands the teeth of time ( Dutch expression don't know if it exists in English too ) than the newer analogue synth's , so it'll be.
thanks you all for the info]
ps btw the digital board in my signature was upgraded by RL , so guess it's still hole thru.
sunny pedaal
Postby Tibbon » Mon Dec 03, 2012 9:34 pm
It still really isn't that bad to work on SMD. Most synth companies aren't using tiny SMD parts (603 or bigger in most synths).
The only special tool that you *might* need is a hot air rework station. These start at $99 new and go up from there. I think my soldering iron was in that price range, and a good scope (when new) can easily run into the thousands. In short, setting yourself up for surface mount work isn't that much money. A steady hand and a good magnifier can do a lot to help.
Finding the fault is the hardest part, but that's really true with any circuit. Sometimes these days it isn't about wanting to do SMD, but the requirement of doing SMD if you want to use some parts. Through hole is going the way of the dodo slowly. You simply can't get some stuff as through hole now, and in the future that's going to be more and more true.
Signature #144
Tibbon
Postby Voltor07 » Mon Dec 03, 2012 9:41 pm
Never seen the inside of a Little Phatty, have you, Tibbon? There are many tiny components on those boards.
Voltor07
Postby thealien666 » Mon Dec 03, 2012 10:46 pm
As anyone who has ever tried replacing an SMD resistor will tell you; these things are focking small ! :mrgreen:
And did you know that there is now a sub-SMD format that almost only robots can handle (or Swiss watchmakers :wink: ) ?
As demonstrated in the picture below, where the bigger rectangle shaped capacitors are "standard" SMD size and the resistors (with numbers printed on them) are the new smaller size no bigger than about 10 grains of table salt :shock: :
thealien666
Next
Return to Voyager Forum
Who is online
