Moog Music Forum
Share Ideas and Pass the word
Does my Voyager OS need a synth doctor?
Tips and techniques for the Voyager
Postby elmdragon » Fri Nov 09, 2012 3:44 pm
Hi all. I recently picked up a second hand Voyager OS as a step up from the Little Phatty I've used for a year or so, and it's in mint condition physically. Using it the past few days, however, I've noticed something odd that makes me wonder if there is something not quite right about my new baby.
I'm hoping that one of you other owners out there can tell me if this is normal... or if I'm going to need to call the Moog Synth Docs for treatment.
What I've discovered is that turning off "3 KB Cont" in the Oscillators section, Osc 2 goes sharp by about 3 semitones. It returns to normal if I turn 3 KB Cont on again. If 1-2 Sync is on at the same time as 3 KB Cont is off, Osc 2 jumps a full octave higher in pitch. (As in if I dial up a dual-sawtooth patch identically on both the OS and the Phatty and then turn Sync on both, I have to turn Osc 2 down an octave to sound the same as the Phatty).
Of course, I'm not trying to get my OS to sound exactly like the LP - but I want my Voyager to behave the way it is supposed to, and this just doesn't seem right.
By the way, if I try using Sync while 3 KB Cont is on, the sound doesn't have that wail/sheen that I associated with synced oscillators. I mean I can hear a difference in that there is no wave cancellation from two separate oscillators audible, but unless I turn 3 KB Cont off, it doesn't sound anything like the Sync sounds I get from the LP.
So what do you think? Do I have a problem with my Voyager, or is this the way it should be functioning and I should get on with enjoying the sweet sounds I can get from it?
Thanks in advance for your time!
elmdragon
Re: Does my Voyager OS need a synth doctor?
Postby EMwhite » Sat Nov 10, 2012 1:52 pm
No, that's not normal; but make sure you don't have any strange modulation setup where by you have a buss leveraging OSC3 as source, pitch as dest (I'm not in front of my kbd so cannot visualize the options).
But seen weirdness like you describe, just not on my VOS. I have an OSC module that wavers pitch when I change PWM setting. And when I adjust gate time on a q119 sequencer, the rate slows down but I think the latter is a firmware issue, not something relating to ref voltage.
Moog Voyager Old School, LP Tribute, Taurus 3, Opus 3; Ob: Matrix 1000 and SEMs; Blofeld; too much modular stuffis; Kurzweil 250; Hammond M3; Fender '75 Jazz, Tony Franklin Fretless Monster; MusicMan Stingray; Mesa Amps; MF101,102,104M,105M,MP201
EMwhite
Postby thealien666 » Sat Nov 10, 2012 6:32 pm
elmdragon, make sure that both "amount" knobs in the "mod buss 1" and "mod buss 2" are fully counterclockwise (no modulation). If osc 2 still goes up in pitch when switching off "3 KB Cont.", then something is wrong with your Old School.
BTW, the Sync works only on Osc 1 and Osc2. When flipping the "1-2 sync" switch, Osc2 becomes a slave, and Osc 1 is the master. Osc 2 should then be set equal, or higher, in pitch than Osc 1 in order to get the typical sync sound (by varying Osc 2 frequency).
Osc 3 has nothing to do with the sync function. If the sync of Osc 2 to Osc 1 doesn't work like it should when "3 KB Cont" is set to "on", then there is definitely something very wrong with your Old School.
Well, it has five forward speeds..What, you mean electronic gear ? Got cruise control.. mmh what ? Oh, you mean musical equipment gear ? It has a nice sound system too.
http://www.youtube.com/alainhubert
http://www.soundcloud.com/thealien666
thealien666
Postby elmdragon » Sun Nov 11, 2012 1:20 am
Yeah, I thought as much. Thanks for the confirmations; I've definitely verified that with modulation amounts set to zero on both busses the pitch of Osc 2 varies with the setting of 3 KB Cont. Also, it seems that regardless of how I set Osc 1 and 2, Sync just isn't sounding right unless I turn off 3 KB Cont.
I guess I'm gonna need to put in that call to Moog - and I just got her as well... :cry: I just hope it's nothing too expensive to patch up.
Thanks to both of you for your input!
elmdragon
Postby Kenneth » Sun Nov 11, 2012 9:56 am
What is your location? I would strongly suggest finding a local tech to do the work. Shipping to Asheville is an option Voyager owners should not take lightly. Who knows what happens to our synthesizers when they're being manhandled by postal employees...
THE CAPS ON THE JACKS ON THE BACK ARE BLACK.
Kenneth
Postby elmdragon » Sun Nov 11, 2012 10:50 am
I'm in Monroe, GA. Asheville is about three and a half hours drive from here; I could possibly do that, but an authorized tech nearby would be a better idea, I agree. Shipping expensive synths about doesn't exactly make me smile either. I'll have to check on authorized techs in the Atlanta area and see what my options are.
elmdragon
Postby EMwhite » Mon Nov 12, 2012 3:25 pm
I've taken my Little Phatty Tribute (for CV out mod and RAM upgrade) and my Voyager Old School (for other modes and calibration) separately to Asheville, once on a drive over from Raleigh during a business trip and the other time on the way driving to Florida with family. But in both cases, I had Moog ship it back to me.
No issues but I'm not saying that you won't have issues because you never know.
If it's your baby, take the drive, especially if you've never been to Asheville, leave at 6am; get there around the time they open, check out the demo room, schedule a factory tour through Jason, have some lunch in Asheville and head back by evening. Well worth the day investment to check the place out. If you coordinate it ahead of time, maybe they can slot you in to do the work while you hang around the area? I can't see it taking more than a few hours to resolve but I'm guessing.
EMwhite
Postby elmdragon » Mon Nov 12, 2012 5:52 pm
An excellent suggestion EMWhite! I think I'll try to do something like that with the tour and such - could be quite a nice day. That would indeed be awesome if they could coordinate with me to get things done whilst I'm there hanging out.
elmdragon
Postby nightfur » Mon Nov 12, 2012 6:15 pm
Old School's are known to have Oscillator issues occasionally - they may need to replace some components - this hapened to me recently. I had subsonic oscillators and one didn't work at all! Moog was quick to resolve the issue.
nightfur
Postby elmdragon » Tue Nov 13, 2012 11:59 am
Nightfur, thanks for the info. If I may ask, was your oscillator work outside of warranty? If so, could you share an approximate cost (I do understand that costs would vary, perhaps greatly, based on the nature of the specific problem). I'm trying to get a feel for how much cash I'll need to have available, as in a couple hundred, several hundred, a thousand or more, when I initiate the process.
elmdragon
Postby nightfur » Tue Nov 13, 2012 7:30 pm
Luckily my repair was still under the 1 year warranty. I'd guess you'd be looking at several hundred dollars, but there is no way I can know for sure. I would consult with a Moog tech.
nightfur
Return to Voyager Forum
Who is online
Users browsing this forum: CommonCrawl [Bot], Google [Bot] and 1 guest
