Hello!
I may have a problem with my moog but I am not sure if this is normal because its my first 100% analog synth. I have a noise on my moog when i play a note but the "noise" is turned off and volume down. Its better to hear it when the cutoff is down, so mostly bass. you can hear it better at the end of the audiofile.
http://audiowerk.at/moog/1_noise_when_playing_note.wav
2nd thing: I can still hear a note playing after I released the sound. its very slightly in the background also when Master volume is down 100%. This is not happening on the phones output. so i am confused.
http://audiowerk.at/moog/2_output_if_vol_is_minimum.mkv
3rd thing: Maybe this is no problem because i have read about self oscilating. I can play the synth with all channels down and switched off on the mixer. this is when i do the resonance all the way up.
http://audiowerk.at/moog/3_selfoscillating.mkv
I am very confused about all this becouse i have already sent it back for repair in europe and got it back the same without a thing changed. So i don´t want to bother the european dealer for nothing. i hope you understand my bad english!
Kind Regards!
Benjamin
