Moog Music Forum
Share Ideas and Pass the word
Perfect Partner for Voyager?
Tips and techniques for the Voyager
Re: Perfect Partner for Voyager?
Postby thealien666 » Wed Oct 31, 2012 2:46 pm
restlessboy wrote:...You could have a slider which grows to twice its size when you touch it - allowing really precise control.
I will add a little to this rant: those sliders could easily move by themselves, showing their changing values as the sounds are played (like virtual motorized faders), and come back to their set position once the sound is stopped to show the value set in memory ?
You will have guessed that I also despise those rotary knob emulation and their crappy, counter intuitive, interface.
Rant over.
Alain.
Well, it has five forward speeds..What, you mean electronic gear ? Got cruise control.. mmh what ? Oh, you mean musical equipment gear ? It has a nice sound system too.
http://www.youtube.com/alainhubert
http://www.soundcloud.com/thealien666
thealien666
Postby restlessboy » Wed Oct 31, 2012 3:45 pm
Exactly. There's no reason controls on touchscreens need to be restricted by copying real world physical controls. Just look the Lemur and stuff like that.
Maybe we should form a mob and head to the Animoog forum? :)
restlessboy
Postby stiiiiiiive » Thu Nov 01, 2012 8:49 am
restlessboy wrote:Exactly. There's no reason controls on touchscreens need to be restricted by copying real world physical controls.
I guess ANIMOOG has to look like ANY MOOG... :wink:
stiiiiiiive
Postby MC » Thu Nov 01, 2012 1:38 pm
There are many potential partners for the Voyager
MC
Postby filtered » Thu Nov 01, 2012 2:15 pm
Does it have to be a synth? I love comping chords on my Wurly while doing Voyager melodies! variety's the spice of life!
http://www.youtube.com/user/moogslob?feature=mhee
http://www.carversmusic.com
http://www.moped10.com
[url]http://www.facebook.com/pages/The-NoSeRiDeRs/​81571989428[/url]
filtered
Postby stiiiiiiive » Thu Nov 01, 2012 2:52 pm
Ditto.
And eventhough you only have an EP, some well choosen pedals can make pads out of it. I saw a band (don't remember if it was here or on the Elektron forum) whose trio video showed he was using a Rhodes but the sounds were some kinds of wonderful jazzy chorused seagulls...
stiiiiiiive
Postby bhrama » Thu Nov 01, 2012 8:30 pm
I can say the P08 does make a nice match for the Voyager, I had an early version and upgraded it to the PE version. HOWEVER....I upgraded that to a P5 and I can swear to you that this is truly a match made in heaven! 8)
Voyager EB, Prophet 5 Rev 3.0, DSI Tempest, Eventide Space, Strymon Timeline
bhrama
Postby Kenneth » Fri Nov 02, 2012 9:18 am
stiiiiiiive wrote:Ditto.
Radiohead do all sorts of ambient pad sounds with their Rhodes. Chorus, phaser, delay, reverb...
THE CAPS ON THE JACKS ON THE BACK ARE BLACK.
Kenneth
Postby Kenneth » Fri Nov 02, 2012 9:19 am
bhrama wrote:I can say the P08 does make a nice match for the Voyager, I had an early version and upgraded it to the PE version. HOWEVER....I upgraded that to a P5 and I can swear to you that this is truly a match made in heaven! 8)
Had a dream the other night that I played a Prophet 5... That's as close to playing one as I've come. :)
Kenneth
Postby stiiiiiiive » Fri Nov 02, 2012 9:40 am
Can you give some specific examples, Kenneth?
stiiiiiiive
Postby Kenneth » Fri Nov 02, 2012 10:39 am
http://www.youtube.com/watch?v=fSpJEuNZxIk
Kenneth
Postby restlessboy » Fri Nov 02, 2012 10:57 am
Has anyone any comments on passing a P08 through the Voyager filter? I assume that wouldn't be too difficult. I'm guessing you slave (if that's the right word) the P08 so you're playing it with the V keyboard - so the filter opens/responds to whatever envelope or modulation when you press the key (is that right?) – then feed the audio out from the P08 into the external input jack pre-filter. Plus mute all the Voyager’s oscillators (or don’t!).
The only downside I see is the reduction of all the possible P08 outputs from dual stereo to mono.
So, yeah. Not a question really, just thinking aloud and inviting any thoughts.
restlessboy
Postby stiiiiiiive » Fri Nov 02, 2012 11:15 am
(Thanks Kenneth, I'll watch this :) )
RestlessBoy, another drawback is the fact you'll be fine for monophonic lines, but for polyphonic stuffs, you may obtain something a bit weirder. Like a paraphonic synth, Opus 3 etc.
stiiiiiiive
Postby restlessboy » Fri Nov 02, 2012 12:12 pm
I thought the Voyager keyboard could be used as a polyphonic midi controller?
restlessboy
Postby ColorForm2113 » Fri Nov 02, 2012 12:31 pm
restlessboy wrote:I thought the Voyager keyboard could be used as a polyphonic midi controller?
It can be but the p'08 is one filter per voice (8 filters) where if you run it through the voyager you get the same filter for all 8 voices. Not necessarily a bad thing just sounds different. More like the string synths of the 70's
MOOG GEAR: Voyager select series Mahogany/Electric blue, Micromoog, Etherwave Theremin, MF101, MF102, MF103, MF104m MF105, MF108m, CP-251, VX-351
ColorForm2113
PreviousNext
Return to Voyager Forum
Who is online
Users browsing this forum: CommonCrawl [Bot] and 1 guest
