I can't seem to get animoog to send channel pressure or for that matter polyphonic pressure on midi out. I have either or both turned on on the setup page.
I've been trying to do this using midimux into Ableton Live on a Mac Pro. I also tried using an iConnect midi box, but so far no luck.
I'm running a midi monitor in Ableton, and can see that no channel pressure is being sent. All other controllers work fine.
Am I missing something?
Peter Hannan
animoog channel pressure on midi out
Re: animoog channel pressure on midi out
Is it possible that the MidiMux is filtering out the channel pressure?
That thought had occurred to me too.
If its possible to discover if anything is filtered in Midimux, I have not been able to find that information.
In any case, I then tried with my iConnect Midi box, with the same result.
