Axiom 49 controlling Animoog
So I have got the Animoog setting to recognize the Axiom keyboard and can play notes - but that's all. I can't seem to use the knobs or sliders on the keyboard to do anything in Amimoog. Anyone know how I can map those controls? Would really be able to tweak cutoff, etc from the controller.
Re: Axiom 49 controlling Animoog
come on... I know someone out there's got something?
iPhone or iPad, and how is the keyboard connected to your iOS device?
First, use some sort of MIDI monitor app on your iOS device to make sure all your keyboard controls are sending the required CC messages.
For Animoog on the iPad, MIDI learn is enabled by going to SETUP, MIDI, MAP CC's.
This will put a red block around all the mappable controls.
Tap on the control you want to map, and it turns green, indicating it is in "learn" mode.
Send the CC from your MIDI controller by moving the control you want to map, and you should be set.
Turn off MAP CC's when you're done.
Once you get all your mappings in place, recommend you save your mappings using the SAVE/LOAD CC MAP option.
