Hello,
someone can explain to me how can I record the automation hardware in the midi file played with Minitaur, if I press "R" in the track "External midi" I see the parameters recorded in midi files (several columns of different heights) but then when I play again the midi track with the Moog sounds with the latest "hardware" used settings and not with those registered on the midi files also happens that after a while the moog will reset the sound and gives me the moog Minitaur editor settings of the initial preset, and not the latest hardware settings set by me.
so, I need to record the Live hardware changes in the midi file ready in the track "external midi", and also if I start from a preset and modify via hardware I do not want to reset itself after a while giving me the initial presets without having touched or recorded anything in the original midi file "dry".
Thank you,
Best
Moog MINITAUR midi automation events Logic pro X
