Can I further limit the minitaur note range?
I'm thinking about getting a minitaur to use with an organ that transmits on channel 2 from the lower manual. I know the minitaur is limited to an octave above middle C, but I'm curious if I could limit it more, and have it only respond to notes below middle C. Or in other words I want to modify the minitaur note range (ex. 0-60 or 0-48), because the controller doesn't have an option to limit the output note range. Is this possible?
Re: Can I further limit the minitaur note range?
It is not possible. And I don't think Moog will this implement this seldom needed feature. It will rather cause trouble if users set it and forget about this.
Sequence:
Sequence:
