It seems that the Filter ADSR Sustain knob raises the pitch of the oscillators about a 1/4 tone-- is this normal?
Many thanks!
Filter Sustain changes pitch?
Re: Filter Sustain changes pitch?
Hi Enoki,
It sounds like you may actually have the LFO modulating the VCO. Try turning the LFO VCO AMT knob up and then down and see if you have the same issues. (make sure the mod wheel on your MIDI controller is down as well) If this does not correct the issues, please contact our support department as the Filter Env does not affect the VCO in a Minitaur.
http://www.moogmusic.com/contact
Hope this helps
-Your Friends at Moog
Hope this helps
