I am somewhat space constrained and I don't have space to dedicate 3U to one Minitaur. A very likely appears to be mounting it next to a CP-251 in the rack mount kit used for the CP-251, VX351, and VX-352. Working from the dimensions in the spec for the Minitaur; 8.75" x 5.12" x 3.12", and the actual rack mount kit and CP-251, that once you remove the CP-251 side panel there is enough room* side-to-side to fit. However, the Minitaur front panel presents a rather challenging angle.
I would very much like to get stuff up and off a non-existent desk surface and mounted to the wall. If the above doesn't work, I may have to skip rack mounting the CP-251 as well, favoring some other synth or effect.
Of course, I would rather have these problems than to forgo Moog's altogether!
*- the screw heads on the sides may also present challenges.
Minitaur rack mount options
2xMother 32, DFAM, Subharmonicon;
Re: Minitaur rack mount options
I am wondering the same thing. Has anyone mounted the Minitaur next to the CP?
If we don't get an answer by Wednesday, my Minitaur will be here anyway.
My Minitaur came today, and while there is space on the CP-251 rack mount bracket to accommodate it. You have to remove one of the wooden side panels of the CP-251 and provide someway to attach it - there are no matching mounting holes.
I'll post some pix before friday. [ran out of time this week]
yes, please keep us updated.
