Recording Moogs
Recording Moogs
Hi, When recording a moog, what is your setup? Do you go DI into computer interface or mic an amp? If so which amp do you recommend?
Re: Recording Moogs
Normally I record directly into a mixer channel. You can record directly into your audio interface too. Just make sure your levels are good. I wouldn't personally record an electronic instrument via amp/mic but some performers have done so with interesting results.
Re: Recording Moogs
I have a Mackie Onyx 1220i which is also my audio interface (via Firewire to my Mac). I go directly into the board without a DI box and record using Reaper.
It's wonderfully clean and crisp!
I used to go through some hardware effect boxes (distortion, flanger, echo) prior to the mixer but lately I've been bypassing these boxes in favour of software effects.
Re: Recording Moogs
You certainly don't need a 'DI box'.
A DI (direct injection) box converts a high-impedance, unbalanced signal, typically from a guitar/bass to a balanced low-impedance signal suitable for directly connecting to a mixing desk's mic preamp inputs via an XLR connector.
Any synth can connect directly to a mixer channel's 'line' input without any DI boxes or other extras, whether from the synth's 'line output' or directly from the panel of a modular (with attenuation on the channel if necessary).
